Question about Honda 13 Hp 4000psi 4gpm Pressure Washer Ez4040 Pump
Will not run if choke is all the way off.but will run half way on.
rlev_7
    New Friend:
  • 47 Answers
Sounds like a carb problem
Posted on Sep 09, 2010
John deere pressure washer will start up and run fine on half choke. After a short time i open up the choke full open. The dump valve works fine but when i squeeze handle on wand to work the motor shuts...
Mine run like that right from the factory so I just left mine on half choke. The store told me it has something to do with the settings at the factory. It was set to run in a certain country with the air pressure. They told me to run it on half choke. all the time.
Jun 17, 2018 | John Deere Garden
My murray weedeater want run off choke why?
Carburetor needs to be rebuilt. I won't even think twice about. the diaphram is on it's way out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Aug 29, 2017 | Weedeater Garden
Put choke to run it pops put choke half way runs good
dirt or water in carburetor.Choke helps suck more gas in engine to run better.
Dec 28, 2013 | Garden
Honda EU 3000is only runs on half choke
Overhaul the carb. When you have to choke it to run, there is not enough fuel getting in
May 04, 2013 | Honda EU3000iS Inverter Generator
My honda vtx 1300 will not run with choke all the way in but will run with the choke half way in. what is the problem?
If your bike will only run with the choke half way out it's starving for feul. You have a clogged jet. By choking the bike you cut off the air and allow more feul to run through the carb.
Oct 30, 2012 | Honda Motorcycles
I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How can you start a Ariens 824 snowblower
Ignition key on, throttle three quarters on, full choke, press primer 3 or 4 times, pull cord. Should cough, maybe start and run rough, then as it's chugging, turn choke to half, then quarter choke, let it warm up slightly, then choke off.
Dec 05, 2009 | Ariens Garden
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
Honda 13 Hp  4000psi 4gpm Pressure Washer Ez4040 Pump Logo
131 people viewed this question
Top Honda Plumbing Experts
rlev_7
Level 1 Expert
ray gallant
Renee Knafel-Bullock
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
