Would almost certainly be blocked pilot jet and pilot circuit a classic symptom of this is running only with choke on
buy new pilot jet an compress air clean the hole the pilot jet screws into
regards Jamie
check to see if your carbs. are on tight. 2. might have stopped up low speed jets,might have to clean carbs. synchronize them.check air filter and sparkplugs,and gas line filter.
it sounds like you need a carb clean performed. the idle cuciut jet is probably dirty and that is the jet that supplies gas to the combustion process at idle rpm's. when you have the choke pulled out it is adding fuel and air so when you shut off the choke the fuel supply goes away. for the oils use yamalube 2 stroke oil for pre-mix and 10w -30 gear oil for your tranny.
