Pioneer DEH-14 CD Player Logo
Posted on Jun 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a car with a piooneer car stereo and want to program radio stations
mwarej123
Level 3:
  • Master 454 Answers
  • Posted on Jun 24, 2010
mwarej123
Master
Level 3:
Answers
454
Questions
Helped
180297
Points
1400
Tune to a station you want to program. Hold one of the station preset buttons down for about 3-4 seconds. It should 'beep' and store the station.
1helpful
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
How do i program the F.M. Stations on my stereo's
It really depends on your radio but most of them you just go to the radio station you want and hold the number you would like it to program to for about 10 seconds
Having programmed by car stereo with the FM stations I required (newly bought car, 1 year old), I find that the programmed button number 3, which is programmed to station 97.3 jumps to 102.7 without...
you may have auto seek (rds) which when the signal is weak it will search for the same station or one it thinks is the same station with a stronger signal, you should be able to turn this function off, also the button normally acts as "2" presets so the switch may be defective
How to lock in radio station on kenwood face off cd player
once you have the station you want to listen to on the radio press and hold one of the buttons along the bottom of the stereos face for a few seconds the screen should flash for a second or two or it should beep as well to indicate its saved it.
if when you turn the ignition off and then turn it back on the stereo has forgotten the station you programmed you need to remove the stereo from the car and check the wiring at the back of the unit. most of them have a red and yellow wire that are joined by metal push fit connectors, swap these two over and it will then remember the station for you.
the red wire is the switched power lead from the ignition and the yellow lead is a constant live feed for it to remember your settings, if these are round the wrong way it will keep forgetting radio stations you program until you switch them over.
hth
Factory radio recieves am stations only no fm stereo
get a new one as they are cheap these days!
& not worth the labour costs to try & fix them anymore!
Cheers Rob
The stereo is Clarion M5675 older.
yes... you may have to push that same number again when it flashes though. its been a while since i played with that radio
How do I set radio stations into my car stereo?
have you tried just holding the preset button down ??
Truoble programing radio stations.
it sounds like the memory wire isnt connected to the correct position the memory wire on the stereo needs to go to b+ also a faulty battery can cause this even if the battery can still start the car. an auto electrician should be able to test the battery for free to eliminate that as the problem
Tunining Radio Stations on a Clarion ADX5555z
Google the model and download the manual.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
