Frigidaire FAP094P1Z Portable Air Conditioner Logo
Posted on Dec 30, 2017
Setting up a portable air conditioner
We are getting ready to set up our portable air conditioner, it has been in storage since last summer. It is a frigidaire model #FAPO9EP1Z1, my question is, it has some water in it from last year, do we need to get that water out or can we just start it up. If we need to get the water out, how do we do it?
5 Related Answers
Anonymous
  • 230 Answers
  • Posted on Jun 30, 2008
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Anonymous
  • 534 Answers
  • Posted on Jul 28, 2009
SOURCE: MY 2YEAR OLD WINDOW AIR CONDITIONER WON'T POWER ON
Apparently the gfci on the plug (the reset button) has gone bad. The best thing to do is to purchase a new cord and replace it. These switches sometimes go bad. Good Luck
Dave
Anonymous
  • Posted on Aug 05, 2009
SOURCE: My portable frigidaire air conditioner bucket light on
The actual bucket is located inside the machine at the bottom.  To access it, you must unscrew all of the screws and take the front panel off.  You cannot empty it from this side so it is not worth taking the machine apart.
However, in order to empty the bucket, there is a small black plug at the bottom left hand side at the rear of the machine.  Be careful when pulling out the plug because the water will immediately drain.
Good luck.
m
Anonymous
  • 16 Answers
  • Posted on Mar 19, 2010
SOURCE: I am turning on my window air conditioner for the
get your AC serviced, due to dust and all the coils are choked this is the reason for water is comming out from the evtns
Anonymous
  • 1515 Answers
  • Posted on May 13, 2010
Hi, what is going on is the unit is working good so you will have condensation running down the front of the indoor coil. You will have a trough at the bottom that has collected dirt over the winter and has clogged up the drain. Some window units have a small supple clear hose attached to one end of the coil that may be plugged up, or this unit has what we call weep holes around it starting at the inside edges on each corner and around the out side. Go outdoors and look and see if you see a hose or very small holes that are plugged up. If the hose/if there is one, try and blow it out. What is happening, is the blade from the fan motor is picking up the water and slinging it into the home. Yes, you can solve this once you find how it drains and where it drains. Take a good strong light inside to check the front and see if indeed there is a hose. Keep me posted on this and I hope that I have led you in the right direction to solve this, and I am sure I have. Please let me know.
Sincerely,
Shastalater7
2helpful
Override temperture setting on Amcor Amc-12000e portable Air Conditioner
Actually there is no way to do what you want because the unit is designed to operate when the inside temperature allows the heat exchanger to function so that it will condense the liquid refrigerant into a gas.
As far as using it in the winter to dehumidify this same applies. If it is to cold then the gas won't be able to condense back into a liquid. If I were you I would buy a portable dehumidifier but remember that if the temperature is to low it won't work.
Good luck
Marty
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Power button indicates a cooling mode but I don't hear the compressor come on and the air coming out is not cool. Seems to have worked earlier this summer but sometimes the cooling seem spotty. Tried...
You may not have the temperature set low enough to make the compressor turn ON. Lower the setting until it does. This will give you an indication, where you need to leave it set.
Thanks for choosing FixYa.
LG 1210 BXR portable air conditioner collecting water on "cool" setting. How do you fix this?
In AC mode, the unit still has some dehumidifying properties. So, it may be that there is more humidity in the air this Summer, than in prior years. Having to empty the tank every 24 hours is not unusual. Be sure that the air intake filter is clean & check the exhaust hose for obstructions.
Hope this helped you & thanks fr choosing FixYa.
1helpful
I have a GE APE08AKM1 portable A/C unit. The first summer it blew cold air.The next summer it was so-so. This summer it just blows It believe it leaked the freon or what ever it uses out. Is it cost...
sounds like it has a very small leak. Unless it can be detected Its
probably not worth it,
unless you have a ser man to add ea. year.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
[email protected]
Motor still runs after cool air stops coming out
See if helping the fan turn will get it going thrn let it run awhile.. The fan motors rake a set if not used often enough.
4answers
Room temperature has not changed since hooking up new portable a/c
This may sound dumb but ( 1) Do you have the warm air from the unit to the exterior of the space? If the condenser is in the space your putting the heat your trying to remove right back into the space. ( 2 ) There should be an air supply and an air return in the space only. With that there should be a temperature difference of 16 to 20 degrees between the supply and return. ( 3 )A 1 ton unit usually will cool approximately 400 square feet. ( 4 ) It may take a while to pull the space temp down due to pulling the heat and moisture from the ceiling, walls, and floor. This could take 6 hours or more the first time you use the system in a space.
Not cooling
1. check doors,windows,of room
2.if there is leakage freash air came in.so temparature can not maintend
Top Frigidaire Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
