SOURCE: Can't get past the Align Screen
When you first start the device, it asks you to tap the screen to begin. Tap the screen, do not hit any of the buttons. If it does not work, I'm sorry to say it will most likely be the touchscreen. As wonderful as the i700 is, it's still delicate technology. The touchscreen is a horrible repair to undertake, unless of course you happen to find a replacement on ebay. Replacement services are around $169. Doing it yourself is easy enough, save finding the parts. Another unit from ebay is a good bet. That's what I did. The repair is simple enough. In fact, you can find a video on Google video that shows you how to remove the screen. Good luck.
SOURCE: screen
your touch panel could have died and you may need to replace it. i would try updating the firmware too that fixed a similar issue for me
SOURCE: align screen
ur Touch panel or in other word Digitizer is faulty try getting it replaced it is around 60 or 70 $ , if u dont want to spend money right now and just want to get rid of this screen alignment process just google 'bypass screen alignment ' there is a utility for that just connect ur pda using usb cable and bypass this process but u will not gett correct response when u touch the screen u will get mis aligned response if u want to get rid of this u have to spent money on hardware replacement
SOURCE: Ipaq rx-3115 stops at align screen after reset
This happened to me and i got so mad that i broke the screen. But that was a good idea because then i got a new screen and now it works fine. Just get another screen and it should work fine. or you can just get the digitizer part and swap out your LCD parts.
SOURCE: i cant get past the align screen on my o2
When you don't charge your PDA's battery for a while, and let both normal and backup batteries to finish completely, all your data in your PDA is lost, and it will go back to factory default state. As the operating system is stored in the ROM of your PDA, it will be reinstalled when you charge it again, and becuase there's no data left from the past state, you have to do all the settings again from the start, beginning with the screen alignment (You can tap carefully on the plus sign each time it moves). If you had a backup syncronized with your PC, you can then recover your data to your PDA.
