Windows XP/Vista/7 should automatically use its own drivers, so that you can read from CD/DVD disks.
You'll need "extra" software if you want to play a DVD-movie, or if you want to write CD/DVD disks,
e.g., 'PowerDVD' to "play", and Nero Burning to "write".
CD/DVD Driver is Operating System generic. i.e the Operating System will install the Device Driver for the CD/DVD Drive. If CD/DVD Drive is having yellow exclamatory mark in device manager, then you should delete the Upper and/or Lower filer from registry.
-->Please press Windows+R key to get Run command.
Note
You may also see an UpperFilters.bak registry entry. You do not have to
remove that entry. Click UpperFilters
only. If you do not see the UpperFilters registry entry, you still might
have to remove the LowerFilters registry entry. To do this, go to step
8.
Note
If you do not see the LowerFilters registry entry, unfortunately this
content cannot help you any further. Go to the "Next Steps"
section for information about how you can find more solutions or more
help on the Microsoft Web site.
Go this this website
http://www.bioticaindia.com/gsa-t20n.html
Download the drivers.
Once the file is downloaded, then double-click on the file. It will then install itself on your computer.
Once it is done being installed, then restart your computer. And then you can use it.
