Question about Coleman 10' X 10' Sundome Tent 9160K101
I need a Coleman Back Max Pressure Washer manual. 3000 PSI 2.5 G/Min
Posted by shadoryder on
Kelly
  • 3,740 Answers
If you have your model number.... go to this page find your model number and download the users manual AND the parts manual:
http://www.powermate.com/productmanuals.php?cat_id=3
Or you can contact them:
http://www.powermate.com/faq.php?cat_id=6&faq_id=88
How can I obtain a replacement operator's manual? If you misplaced your operator's manual, you can order a replacement copy by calling our toll-free hotline at (800) 445-1805. Be sure to have your model number handy, so we can send you the appropriate copy.
Thanks for choosing FixYa.
Kelly
Posted on Jun 24, 2010
Brute pressure washer not building up water pressure
I'd love to help but need the model #.
look on the base frame for the model # sticker.
Brute Pressure Washer replacement parts repair kits and upgrade...
look in the link for your model # to find the owners manual and replacement parts
May 03, 2014 | Honda Black Max 3000 Psi Pressure Washer
Black max 3000 honda pressure washer won't start
You need two things for the engine to start, spark and fuel. Pull the plug, hold it close to the engine and pull the starter cord- check for spark. If there is spark (most likely there wil be spark), then it is a fuel problem. Try a little startiing fluid into the breather and see if that gets it to start. If that works, then the problem is in the carbureator - it probably needs to be rebuilt if the engine has been sitting for a while.
Apr 13, 2014 | Honda Black Max 3000 Psi Pressure Washer
Iam wanting to buy a 2-way cylinder to run off one of my outlets i need to know the pressure that my sk 1020 has ; in order to buy the correct one
Type Komatsu sk1020
Pump Gear
Max. flow - auxiliary hydraulic 21 gal/min 80 ltr./min
Max. pressure - auxiliary hydraulic 3,045 psi 210 bar
Control valve 3 elements fully Servo-controlled
High flow auxiliary hydraulic system "SUPER FLOW" (OPTIONAL):
Max. flow 34 gal/min 130 ltr./min
Max. pressure 3,045 psi 210 bar
cheers
Joe
www.barter-joes.com
Feb 12, 2011 | Computers & Internet
We have a Black Max 3000 psi with a Honda GC 190 engine and the water will not come out of the power washer anymore
cud b a few things 1.check filter 2.check 2 c if water is returning tru the over flow 3screw down pressure valve as far as u can
Aug 02, 2010 | Honda Black Max 3000 Psi Pressure Washer
It shuts off during use then starts right back up.
Most of the time it is due to fuel lock - very hot engine. Easy to check, run engine with gas cap loose (not with full tank, fuel may spill out). Replace cap or open vent if necessary. Other problems include low or dirty oil causing oil senser to shut down engine, or hot engine due to obstruction of airway under cover and finally pressure set too high. I find that most pressure washers are set to max pressure. I like to set pressure to 70 % of capacity making components last longer. How long would a car/truck last if you drove it at max speed everywhere? Good luck with your repair.
Jul 07, 2010 | Coleman Pressure Washer PW0881800
Coleman 10' X 10' Sundome Tent 9160K101 Logo
186 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
Vernon Taylor
john h
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
