Question about Nokia 1600 Cellular Phone
I seem to have blocked incoming calls from my daughter - help
A cell phone number shows blocked whin rung - How can I unblock the callers nuumber?
Posted by isobelgregor on
Anonymous
    New Friend:
I want to block a phone # so they cant call me .
Posted on Aug 05, 2010
How do you unblock an incoming call on my landline
You can't unblock an incoming number that's blocked, but you can call your phone company and see if they have a service that restricts blocked numbers from calling you. The callers would then have to unblock the number to get thru.
Sep 19, 2017 | Lands Phones
Droid z992 shows restricted number rather than my name on recipient phone. How do I fix this.
Caller ID blocking feature may be on go to Settings and then tap on Call on a android phone
From there, tap on Additional Settings and in there, tap on Caller ID
just set the Caller ID to show Number" and it will be unblocked
Oct 03, 2015 | Cell Phones
WIFE`S CELL PHONE # IS BLOCKED, BUT IS NOT IN BLOCKED #S
Have her dial *82 before she dials the home number. If that works she has the cell phone set to block her number. *82 should unblock it for just that one call.
Aug 25, 2014 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
My phone number is blocked, how do i unblock? when calling service that does not except blocked numbers?
go into your menu and go into settings. look for phone settings. you should have at least two options. show my number and hide my number. select show my number and then save. this will allow your phone number to show on caller id
May 12, 2011 | Cell Phones
How to block a number?
I think you can try an app which name LEO Privacy, when you block a certain call with Harassment interception then you can block it forever. It's very amazing. LEO Privacy Applock Boost Hide Android Apps on Google Play
Jan 14, 2011 | Cell Phones
How do i block my number on an outgoing phone call?
i found the answer at http://support.sprint.com/support/article/Block_your_Caller_ID_on_your_outgoing_calls/case-wh164052-20100907-100732?&INTNAV=SU:SP:HDIB
Last Updated: Sep 08, 2010You can block your Caller ID information (name and phone number) on a call-by-call basis. Just dial *67 before dialing the number you're calling, and your information will not show up on their Caller ID display.you can also go to http://support.sprint.com/support/article/Know_the_difference_between_restrict_and_block_on_Caller_ID/case-wh164052-20100907-101149?&INTNAV=SU:SP:HDILast Updated: Sep 08, 2010Restrict Caller ID is a restriction that is placed on your account to completely block your information (name and phone number) from being displayed on any call you make. This has to be done by contacting our Customer Care team.Block Caller ID is something you can do yourself directly on your phone by dialing *67 before the number you're calling. This only affects one call at a time, so you have to dial the code before every call you want to block your Caller ID.**************i did some research and found the answer, please provide me with FAIR feed back i.e. 3 or 4 thumbs up. according to sprints website and also htc support forum there is no way to block the caller id automatically. dont kill the messanger i just wanted to pass the info found on htc and through sprint.
Jan 07, 2011 | HTC Snap S522 Cell Phone
When someone calls me,it displays 'call' on Nokia E71,what to do? I don't have duplicates on my phone and when i type in *#30#,it says 'number of caller is not available'.Please help me
In some instances the caller might have caller-id blocked or a *67 manaul caller id block.
You are correct if you have a duplicate contact entry it does not show the name of the caller incoming.
Nov 19, 2009 | Nokia E71 Smartphone
Can I block any particular incoming no.
With this model of phone you cannot block calls from a particular number but you can restrict incoming calls that are not listed your address book. So effectively you can block a caller but you will be blocking all callers that are not in your address book. Having said that, there are other phone models in the market that can block a particular caller by listing the number in a black list.
Feb 25, 2009 | Sony Ericsson K750i Cellular Phone
Caller id Call Customer Service 1-8O5-465-751O To Fix Issue
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
Oct 13, 2008 | Panasonic KX-TG5672 Twin Cordless Phone
Nokia 1600 Cellular Phone Logo
142 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
