If you are not able to hear sound during the this process, the power supply of the TV is likely failing.
If you are able to hear sound during the 3 minute ordeal, then likely the inverter for the backlight is failing, which can also be caused by a failing lamp as well.
Try this: turn the TV on, wait for it to do its thing. Goto the menus, picture settings, and turn the brightness *down* as far as it will go. Exit out of the menu (save if prompted). Turn the TV off, wait a bit, then back on. If still same issue, it could be the power supply or inverter / lamp assembly. But, if the cycle is shorter, or comes on right away, then it is likely the lamp / inverter.
Mine is doing it too same problem
