Question about Timex Ironman 100 Lap Triathlon Speed/Distance - 5E701
I have replace the batteries in the watch and the heart band and the watch is working but not showing the heart beat. Is there something that needs to be done to sycronize the two?
Posted by marilyn_gray on
4 Related Answers
Anonymous
SOURCE: Timex Ironman 30 lap heart rate does not display
the battery type is written on the back of the watch.
Posted on Jul 20, 2009
Michael Chaffin
  • 183 Answers
SOURCE: I have a Timex Indiglo watch that I
This watch will have what is called and "AC" or All clear to reset it. There should be a white sticker with very small print on the back lid that will walk you through doing this procedure. It typically involves pressing down a tiny lever onto a small metal pad that will reset the watch.
Posted on Sep 17, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: just purchased timex 1440sport watch with heart
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.If you can not sort the problem after following instructions, you may need to replace battery. Rate me, please
Posted on Mar 28, 2010
ansel_albert
Ansel Alberto
  • 248 Answers
SOURCE: watch is not reading any
check if the chest sensor is in proper position and it must be stay flat on the skin. i hope this will works.
Posted on Aug 07, 2011
Two problems with my Polar F6: 1. There is some fade on in the bottom right of my watch. That occured before my battery was replaced. 2. After my battery was replaced the heart rate has been off by 30-60...
Yes, it is a problem with the installation of the battery. If you did not send the watch into an authorized service center then you should do so this time. It is very easy to damage the circuit boards in the watch if not done properly, plus there is a service warranty when going through the service centers. The fade was most likely from the battery dying, but could also have been from a degraded seal and moisture issues.
Link to Authorized Service Center -
I also have "how to" function related info in my tips and tricks page.
Mar 20, 2011 | Polar F6 Wrist Watch
The battery was flat. renewed it and all working EXCEPT it no longer can pick up heart rate from monitor (tried it with another monitor and still will not pick up heart beat) Help Please...about...
i guess stopped of use your strap for a long period of time. so you need to nicely clean the strap and try a lot of times until it work again.
I happend to me before and the strap worked only after the 10th session on the treadmill
Feb 11, 2011 | Polar FT60 Heart Rate Monitor (Purple)...
The ascent reading seems to be very inaccurate and the battery shows low after only a couple rides after installing a new battery. Anyone have a solution for the acent issue?
You need to send the watch into Suunto for service. The watch is obviously having an issue if it will not hold charge with a new battery and the Altimeter is not working correctly.
The Altimeters are Barometric pressure related and occasionally something goes wrong.
My experience is that Suunto is very good about fixing and/ or replacing when this issue arises.
Jan 24, 2011 | Suunto T6c Heart Rate Monitor and Fitness...
I changed the battery in the f6 . I had erratic readings. Now watch seems fine but it wont read heart rate,,,,I get no heart beat at all .
Check out my tips and tricks section for a guide on troubleshooting heart rate readings.
One other possibility if you changed the battery yourself (never recommended) is that some damage or moisture has gotten into your watch and made it impossible for the watch to read heart rate. This is a more common reason than you think and why all manufactures of Heart Rate monitors and other types of watches have you send them in to their authorized service centers.
Dec 08, 2010 | Polar F6 Wrist Watch
How do you put the back, back onto this fs1? The band keeps getting in the way! Back came off easily enough, popped off after unscrewed. Band is still on watch, have tried to slide back into grooves but...
You have to remove band in order to fit caseback back onto the watch. Insert pocket knife blade between band and case lug and pry inwards. This motion should release the band. It will be a lot more difficult to fit the band back on and you will probably need to buy springbar tool. Rate me plz.
Mar 03, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
Polar fs2c battery replacement
Many people replace their own batteries but some of them have problems with replacing the backs and finding (for some unknown reason) the watch no longer works!
I advise you to take your watch to your nearest authorized dealer and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
Mar 03, 2010 | Polar FS3 Heart Rate Monitor Watch
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
Jul 12, 2009 | Timex Ironman Tri 30 Lap Sleek T59671...
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Aug 02, 2008 | Polar F6 Wrist Watch
Timex Ironman 100 Lap Triathlon Speed/Distance - 5E701 Logo
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Timex Watch Expert? Answer questions, earn points and help others
