Tip & How-To about Plumbing
Delta single handle Tub & Shower faucet temperature control adjustment.
Step 1 - Remove handle to gain access to rotational limit stop. Once handle is off there ia a plastic limit stop disc. Remember where it is to start with. Metal handles require a 1/8" allen wrench to remove handle. Plastic handles require removal of cap to access screw to remove with phillip's head screw driver.
Step-2- To adjust the temperature of the water coming out of the valve, pull the disc back to a position where it is possible to remove the Rotational Limit Stop and readjust the teeth to desired position to acheive temperature. Once moved reinsert it into place to test water
Step-3- Clock wise will decrease the temperature and counter clockwise will increase the outlet temperature to a hotter setting. Temperature setting per tooth (notch) could result in 4 to 16 degree's based on inlet water conditions.
Check water temperatures to make sure it is at a safe temperature to avoid scalding. Safe operating temperatures range around 120 degree's. Some may have to be adjusted based on season's.
Winter season's when it is cold outside you may have to turn temperature up due to water coming into house will be colder than it would be in the summer.
