Problem:The sound output from this home stereo receiver has very low volume no matter if the volume knob is low to max position.You can't barely hear nothing from any speakers hook to play tunes via input source such as DVD/CD player.It powers up but just no sound can be barely heard.
SOURCE: No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
SOURCE: no surround sound like the movies
HOOK IT UP FROM A DVD PLAYER OR BLU RAY,,, WITH EITHER COMPONENT OR A OPTICAL CABLE ,,MAKE SURE YOU HAVE ALL OF IT TURNED ON ON THE RECIER SETUP
SOURCE: Pioneer VSX 818V No Sound
First thing to check is the Speaker Select Switch. It will say, "A" "AB" or "Both" it will be displayed on the LCD screen as well. Second if that's ok, Check the "Direct" switch. If it's on, turn it off. Generally if it's on, you will see a blue light if it's on (most receiver's)
If you still have No audio, hook up your DVD to the "Direct" input and turn "Direct" on. If you have audio then. The DSP chip is probably bad and you should take it to a shop and have them bench it first to confirm. Hope this helps
Testimonial: "Got me on right path, but I'm still stuck."
Try to check the audio setting of the player. If you user using optical or coaxial then the audio out put format setting should be Raw other wise it should be PCM. You will see the setting if you go through the menu of the player
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
