SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Testimonial: "worked like a champ!"
SOURCE: Where do I plug rca cables from the cable box into
Depending on what type of connections your cable box has available you can do the following:
1) If yo only have the standard VIDEO & L R AUDIO connections you can use the DTV connection on the back of the V2500. If your cable box also has an S-VHS connection this would be the same connection to use.
2) If you have COMPONENT VIDEO connections on your cable box then you would still use the DTV connection. Looking at the back of your V2500 the regular DTV RCA connections are just to the left of center. Farther over to the left are the COMPONENT VIDEO connections. They are labeled Y, Pb, and Pr. These allow for the higher needs of HD TV transmissions. If your cable box has these connections then making use of them would allow for the best quality for your picture.
The following website has your manual available for download in case you need it:
http://www.devicemanuals.com/guide/Audio%20and%20Video/Yamaha/Yamaha-RX-V2500-Owner%27s-Manual-TVRBek9UVT.html
Please let us know if you need any further assistance with your issue.
Testimonial: "WOW! I am impressed and thankful. Others tried to assist me - but they continued to ask me questions which if I could answer - I wouldn't need help. "
