Question about Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television
Hey i got this panasonic cinema vision projection tv.. When i go to converge the colours everything is all aligned but the spaces in between the centre point and other points have a red ghost on one side and a green one on the other.. Also the screen often shskes at the bottom half on the tv i usually just turn in off for awhile and its good but this is also very frustrating..
Anonymous
    New Friend:
Hey i have a panasonic 56 inch tv and there is no picture to the thing. any sugestions?
Posted on Jul 02, 2010
Panasonic rear projection 52inch cinema vision 1080i hdtv looks 3D with double vision red, blue and green how do I fix
Replace the convergence chips--should be stk-392-110's in the Panasonic.
I have start to finish free instructions for this repair based on the model number----a email address will get them for free.
Panasonic cinema vision tv picture is shadowed
thats a classic convergence issue. You can get the panasonic convergence repair kit for your model from www.tvrepairworld.com which has the parts and the CD with repair instructions.
I'm getting a green / red separation on my screen now. Nothing I do seems to help. This a 2002 projection, HDTV 1080i, Cinema Vision unit.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Where is the convergence board/ chip in my Panasonic cinema vision PT47WX51. And if i know how to solder, would it be hard to fix myself? I did find a website to buy one.
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Your TV will commonly have one or more of the following symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio or Video
You can see some examples and find a fix here...
2helpful
My Panasonic cinema vision projection tv has lost it's focus. It has "double vision". How can it be fixed?
You can get the Convergence repair kit for your model at www.tvrepairworld.com the kit contains the IC, Resistors and the CD with step by step repair instructions.
Tv looks blurry on the right side
You will also find there is colour disorientation in these areas. The reason is that your settings on the york had shifted, also it could be due to failure of the degaussing coil, or if there is any fault with the convergence inside the picture tube which could be a major fault.
Try to degauss, see the picture tube neck for any ring magnets out of alignment, also check the focussing in the rear panel which could have shifted.
1helpful
Panasonic cinema vision pt-53wx54j does not turn on. red power led blinks 3 times.
Hi
Thanks for using FixYa. 3 blinks means convergence output failure and to resolve this you’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
1helpful
Our television suddenly lost its colour alignment
Sounds TV got problem of convergence IC failure and you need to replace two ICs in convergence section.
If you are familiar with TV repair and have soldering tools then can fix it by yourself or ask help to local TV tech.
1helpful
Panasonic cinema vision model pt47wxc43g has double image on bottom of the screen.
Sounds like Convergence Ic's are defective. The best advice would be to contact a Svc. Co.
4helpful
Panasonic cinema vision 1080 hd projection tv shut off and red
thats the error code for the convergence ICs. Replace both STK392-110 Convergence Ics and the 2.2 ohm resistors. You can get the Panasonic rear projection Convergence repair kit #1 at the following link which contains the two ICs and all six resistors plus step by step instructions with pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
