SOURCE: Dometic Rooftop RV Air conditioner
why is our dometic roof top a/c on our boat draining water back into boat. is there a way to clean the drain?
SOURCE: water on the squiral cage side I don't know where its coming from
Water on Squirl Cage could mean clogged spider or media pad not in quite right. Either way the water is splashing of the top of the media and out onto the cage.
SOURCE: Dometic air conditioner blowing cool air
When the cooling slows down, but water is still running off, usually something is icing up. You can turn the unit off, and let it thaw, and try again. Sometimes, if the humidity is high, this is more pronounced. It sounds like you are low on refrigerant. That implies that you have a slight leak. You should have the unit serviced, and the leak repaired.
Best regards, --W/D--
SOURCE: I changed my fan motor and squirl cage blower
If you have changed the motor, I assume that the RPM is the same as the motor you have removed.?
Check the rotation of the new motor, if you have it turning in the wrong direction, it does not matter how fast it turns, it will not send enough air across the evaporator and condenser coils.
Also, if you have changed the motor, you should also change the run capacitor for the power motor.
Hope this info has helped you.
SOURCE: I have a Dometic 579 Series Brisk Air AC.
My sheet shows part # 3100248.420 as fan run capacitor.You may have an updated number. Check voltage outputs labeled on it are same as on old one, and double check wiring is correct, to and from capacitor. Be careful not to mistake compressor start capacitor as well. By sounds of number, it's probably the right one.
Testimonial: "Thanks, your number is correct."
