Question about OnDemand Nova Development Invoices and Estimates Pro (GB0U3C0GN0000NE066) for PC
I have had nova Invoices & Estimates Pro but never installed it. I just found it and installed it. When I try to enter an invoice it freezes and shows an error code 3035 module fmlivoice. Do you hav any suggestions? I emailed NOVA but got no response.
Posted by dpt6463 on
Anonymous
    New Friend:
  • 3 Answers
As far as i know this program you are better off if you trow it away, or return it to the company. Good luck
Posted on Oct 19, 2010
Invoices and estimates pro for window 8.1 64 bit
Unfortunately windows installs are a total jailbreak sometimes. the problem might be with the windows install, not the apps. Try repairing winndows. Put the windows disk in the drive and boot the system. There should be a repair option. Also, try the system file checker, sfc.exe:
Start a cmd prompt as administrator and type in:
sfc /scannow<enter>
You'll need the install disk in the drive for this. If that doesn't work, you'll probably need to reinstall windows from scratch. That sucks, but windows sucks, so you're stuck. After the install, run windows update until it says you're up to date and then install the problematic software first.
May 28, 2014 | Nova Development Invoices & Estimates Pro...
Can you tell me if invoices & estimates pro is compatible with windows 7
Be carfull because it looks to me that this soft ware has been designed for xp. only
Oct 14, 2010 | OnDemand Nova Development Invoices and...
How do I fis a pdf error 8 issue so I can email my forms?
The easiest solution to this problem is to run this program in Virtual PC, XP Mode. Here is the link for the download: http://www.microsoft.com/windows/virtual-pc/download.aspx . Invoices and Estimates Pro now works perfectly for me. Another solution is to download another PDF writer to your hard drive. Instead of choosing "create PDF" or "email" for your document, choose "print", select your new PDF writer, and then save the document to a file OUTSIDE the program. You can then access the file outside the program, print it or email, whatever you need to do with it. Both of these solutions fixed my "error code 8" problem, or at least made the software usable for me. The techs at Nova told me there was no solution to my problem.
Sep 24, 2010 | OnDemand Nova Development Invoices and...
Hello try to open invoice and keep getting customise.exe has stopped working
If you have purchased your software. and it says windows vista compatible it is wrong. it is not. and it will not work. Returnet to the store . if you can. ..
Aug 11, 2010 | OnDemand Nova Development Invoices and...
When i try to email an invoice i get pdf error code 8
instal the acrobat reader the asociate the .pdf file with it in your program.
Nov 29, 2009 | OnDemand Nova Development Invoices and...
CAN'T CREATE NEW INVOICE
After emailing Nova Deveolment I played with the Invoices & estimates software. I was able to open a new invoice by: Clicking on the "paid" invoices folder and then clicking "New".
Dec 27, 2008 | Nova Development Invoices & Estimates Pro...
OnDemand Nova Development Invoices and Estimates Pro (GB0U3C0GN0000NE066) for PC Logo
357 people viewed this question
Top OnDemand Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an OnDemand Computer and Internet Expert? Answer questions, earn points and help others
