Question about Insignia Kix MP3 Player
MY Insignia Kix 1GB MP3 PLAYER DOES NOT TURN ON. IT DOES WORK WHEN IT IS CONNECT TO MY PC, BUT WHEN I DISCONNECT, IT WILL NOT STAY ON. THE SCREEN WILL SHOW (!) THEN IT WILL SAY GOODBYE AND TURN OFF.
Posted by christyherna on
2 Related Answers
redincali
  • 13 Answers
SOURCE: My PC is not recognizing my Insignia KIX MP3 player any longer
Have you tried changing the cable to another one you know works or have you reinstalled your players drivers?
if you haven't done so, try to uninstall the drivers for your device and then reinstall them. With the player plugged into your usb, open up your Device Manager.
for XP, right click your MY Computer on the desktop and select Properties, click the Hardware tab, click on the Device Manager button. Im not a Vista user but on there I believe you open the Properties on My Computer still, then on the left side of the System Information window, click the Device Manager link.
(or hold Windows Key and press the Pause key to open DM)
Once in the DM, locate your player. Usually under the Universal Serial Bus Controllers. It may be named Mass Storage Device or something else. If you cant recognize it in the list, unplug it an plug back in while looking at all the USB deviced currently installed.
If you see no changes at all as you plug/unplug your player then you may have another problem.
Posted on Jun 27, 2009
Anonymous
  • 41 Answers
SOURCE: Insignia 1GB Kix mp3 player works in Mac OS 9, but not OS X Tiger
try using another usb port my macbook sometimes doesn't recognize my USB ports.
Or you could use parallels and run windows
Posted on Jul 06, 2009
How do i successfully charge the Insignia kix mp player
To charge your player, turn your computer on and connect the player with a USB cable. More details can be found in the owner's manual.
Sep 22, 2010 | Insignia Kix MP3 Player
On the screen, it reads WRITING with 2 arrows above it.
I had a similar problem with mine, but this may not apply to you. I used my kix on my new macbook, and it worked fine. But when I tried to use it on my family's xp computer afterwards it said that it was writing and media player wouldn't pick it up but the computer itself did. My guess is the problem comes from switching systems between windows and apple. I also never bothered with disconnecting it "properly", which I recommend since it may have also caused the problem. But tell me if this helps.
Apr 26, 2010 | Insignia Kix NS-1A10F MP3 Player
Stuck on making playlist
im having some problems whit my insignia kix player it is stuck on making playlist an will not move can you help me email me at [email protected]
Jul 21, 2009 | Insignia Kix MP3 Player
Jul 06, 2009 | Insignia Kix MP3 Player
There are songs on my mp3 that i dont want..
1. Plug your Kix MP3 player into the USB port. 2. In Windows, open File Explorer (right-click Start, select Explore). 3. In File Explorer, open Insignia KIX, Fixed Storage, Music. 4. Select and delete any undesired songs and/or folders, except the Music folder.
Apr 04, 2009 | Insignia Kix MP3 Player
How to disconnect mp3 from computer
From a command window run:
C:\WINDOWS\system32\rundll32.exe shell32.dll,Control_RunDLL hotplug.dll
Also, you can try this if it goes away again:
Right click on the taskbar, select properties
click Customize
click on "Safley Remove Hardware", and set to "Always Show"
Jan 03, 2009 | Insignia Kix MP3 Player
Color Screen is black
The LCD is failing. Take it back to Best Buy and they'll either repair or replace it.
May 17, 2008 | Insignia Kix MP3 Player
Frozen on Making Playlist
hi, did you get your problem solved? I just bought it today, and had the exact problem.
Apr 25, 2008 | Insignia Kix MP3 Player
Insignia wont turn on, what should i do?
My son just got the (((( Insignia Kix 1GB MP3 Player Model: NS-1A10S)))))) had the same problem look on the side of the unit for switch that says hold .. move it,, you should see a green color under it ..then push the on button it should come on ... im going to try and put up the user guide in my products ..it shows the switch im talking about.
Oct 13, 2007 | Insignia NS-DA1G MP3 Player
Open Questions:
Insignia Kix MP3 Player Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Steven Wander
Steven Wander
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
