Question about Microsoft Xbox 360 Console
They should recall the xbox 360 and fix 3 rrod on all of them its the way it was built not consumers falt they should not try to cut corners on some thing that cost so much money in such bad times i have 2 one with rrod and one that wont play halo 3 but plays ghost recon fine werd says clean disc but disc is brand new and was working fine till one day i came home and it said clean disc so i had it cleaned and it didnt work still !!!!
Posted by eap04106 on
grimm_army
    Filmmaker:
    Uploaded 5 video answers.
  • 43 Answers
This RROD fix works great. Did it to mine. Consider this if you are no longer under warrenty cuz this will void it if it is.
Posted on Jun 25, 2010
Anonymous
    New Friend:
    Problem Solver:
  • 9 Answers
You can get RROD repaired for free, depending on the error code, speak to customer services, either e-mail or telephone, see microsoft.com, they'll tell you what to do.
Posted on Jun 24, 2010
I hear my xbox cut on everyting plug in right spots no vision just black but i hear
Sounds like you have a fault with the GPU, same fix as the RROD, you need to do the RROD repair.
Mar 29, 2010 | Microsoft Xbox 360 Console
My xbox 360 has no video or sound... No splash screen, nothing... Just a black screen.. No RROD.. I tried 3 av cables and same result.. plaese help
Probably the same problem as the RROD, just without the lights. Reflowing the CPU and GPU and replacing the thermal compound with Artic silver 5 should fix the problem.
Dec 04, 2009 | Microsoft Xbox 360 Console
During game play my video went to garbage and RROD
if your 360 is still in warranty try to send it back to microsoft and ask for recall, cause it´s a hard problem to fix..RROD is terrible to fix, here in Brazil we have the same problem even worst sometimes...to fix your 360 you will need to reflow the bga solder points under the 360 GPU processor.. it is located under the dvd drive...and under the gpu heatsink..after reflowing your gpu..you will need to apply a thermal paste called artic silver...try to change the gpu heatsink with another better one...and install a internal coolermod...Any doubts call me...search for thermalright TR-360 the solution for XBOX !!! Good Luck !!!
Sep 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 problem
Most likely not.
The normal warranty on an Xbox is 1 year.
Due to the number of consoles with the rrod issue, Microsoft extended the warranty for the rrod specific problem to 3 years .
If you're within the 3 year windows but the tamper seal is broken, you can expect to have to pay for the repair.
Jul 18, 2009 | Video Game Consoles & Games
When i turn my xbox 360 on one light in the bottem right corner flash red and it reads E 74 error but when i unplug the xbox from the t.v it doesnt flash red, does this mean we need a new wire
one red light means the video card is dead not the cord and unfortunately cannot be fixed and to make it worse this error is not covered by warranty, if you want it under warranty tel microsoft wen you ring that it has 3 red flashing lights (RROD) not 1 as this error is covered by warranty
Jun 30, 2009 | Microsoft Xbox 360 Console
XBOX 360 - E74 WITH ONE RED LIGHT
Usually when the AV is disconnected all four lights flash red. Cheapest thing to do first is try another AV cord.
However, it's possible that your 360 has been refurbished and the hardware has the chip in a warped position.
If it isn't the AV cable:
You can order a kit for RROD on ebay for about $7.00. Same hardware as what you'd need.
What you have to do is replace the hardware (x clamp) on the video chip the same way it's done when an xbox gets the RROD. reheat the chip so that it connects again by letting it run for about 5-7 minutes with the fan disconnected, turn it off again, wait about 30 seconds and then turn it back on. I fix 360's with this error code at least 3 times a week.
In some cases after doing the clamp trick you will get RROD. No worries, just follow the proccess above and everything will run smoothly.
Jun 02, 2009 | Microsoft Xbox 360 Console
Scratched Xbox 360 motherboard
Usually if a motherboard has been scored or damaged.
( tracks or resistors/capacitors dislodged et,c )
The board is in the Bin. ( scrap ) unless the damage can be repaired. The RROD Or red-ring of death. Is usually due to the x-clamps fitted to the console initially, by the manufacturer.
Replacing the x-clamps, with a kit ( bolts/washers thermal Compound ) And 4 x heatpads recommended. Can cure the RROD. And in my own experience the 1 red light And E74 error.
Bottom line, if the boards scratched. it,s in the Bin.
Mike @ Compurepair.
May 29, 2009 | Microsoft Xbox 360 Console
Ive tried the 3 light fix for the xbox 360 it keep shuting down
Make sure you have all the clamps on the chips tight. If one pops loose it will cause this.
Jan 13, 2009 | Microsoft Xbox 360 Console
Xbox 360 RRD
my son had 3 rings and we bought another power supply cable. it worked he can play all day now. hope that helps. good luck!
Nov 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
76 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
