Question about Measuring Tools & Sensors
Need to rewire from 480 to 240 need coolant pump diagram for colchester # 348337 3 phase motor
Posted by vefalco on
Bob
  • 565 Answers
Assuming that the motor has 9 leads and the wire numbers are still on the wires, for 240 volt 3 phase connections:
Connect T1, T6, and T7 together with L1 (A phase)
Connect T2, T4, and T8 together with L2 (B phase)
Connect T3, T5, and T9 together with L3 (C phase)
If you're not sure which of the incoming wires from the supply are L1, L2, and L3, just pick one. If the rotation is wrong just swap any 2 (TWO) phase wires.
Posted on Jul 04, 2010
How do I rewire a single phase two speed motor?
I suggest you consult the manufacturer or a motor specialist as mistakes must not be made. Sometimes the wiring diagram is printed on the underside of the terminal box. The wiring of multispeed motors can be complex and it is wise to take no chances.
Oct 03, 2017 | Air Tools & Compressors
This is a single phase 1/2 horse motor want to change rotation
yes all you have to do is rewire the wire the motor there should be a diagram om the inside of the the motor panel... dont forget to unplug it first!
Apr 03, 2013 | Air Tools & Compressors
I NEED TO REWIRE A DOERR LR24684 ELECTRIC MOTOR,ITS 1/2 HP, RPM 1725 115 volts to a metal lathe AND ON SWITCH IT'S WRITE- FOR IN DOWN IN CENTER STOP AND UP REV -I SEARCH TO CONNECT THIS...
Motor terminal box sometimes has a connection diagram inside the lid.
Basically a single phase induction motor has a run winding and a start winding and to reverse the direction the connections to one winding, usually the start winding, must be reversed and that is the function of the lathe switch.
Single phase motors are easily damaged and so if any doubt exists I strongly suggest you ask a motor specialist for assisstance.
Oct 09, 2017 | Cars & Trucks
Wire diagram to change a royal sun tan bed model # 46/6 vhr*turbo 1100 from 1 phase to 3 phase
send me your email address and I will give you what I have. We have a 2004 model 46/6 turbo. Wiring diagram is in the manual. I have this.
Jul 26, 2012 | Cars & Trucks
Hi my name is Pat I need the rewiring diagram. So I can rewire my dewalt radial arm saw motor, it is a single phase capicitor motor with built in brake.It`s 120/208-240 volts, 11/5.5 amp, 3450 rpm, 236...
Here's a Google search on the subject:
https://www.google.com/search?q=dewalt+radial+arm+saw+wiring&ie=utf-8&oe=utf-8&client=firefox-b-1
Feb 04, 2018 | Saws
Have a 3 phase compressor model vr5-8 want to know if it can be converted to single phase 230 volt and how
A 3phase motor cannot be rewired to run on single phase power. You need a phase converter. A 3-phase motor will only run on 3-phase power, and a phase converter will convert single phase power to 3 phase. Just google phase converter. There are two basic types, electronic and rotary. The rotary type are more powerful and efficient, but lot's more expensive than the electronic ones. Your only other option is to replace the motor with a single phase motor. Good luck.
May 17, 2011 | Garden
Ac compressor motor is wired for three phase need to rewire for single phase
Most cannot be rewired... but some can... before I can help I do need to know the make and model though...
heatman101
Apr 27, 2011 | Garden
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
Hobart model 5801 meat saw conversion from 3 phase to single phase can it be rewired or need a new motor ?
No, you need a new motor or a converter, but in the case of one saw, it wouldn't be worth the conversion. Just find an old single phase motor that will fit height wise and you should be all set. The speed is the same, the direction can be switched and the HP should not matter much, 1/2 , 1, depends on what you find out there. They all should cut wood no problem. Hope this helps.
Mar 15, 2010 | Saws
Measuring Tools & Sensors Logo
365 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
