Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Lg rd 21FA20 color tv initially audio good distorted picture and raster after 5 min if slaped at back panel bear pcb video good. Now set is dead. When switching on a beep sound comes and power on led flashes. What may be the problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
Well it starte with cold soderl jiont but now you may have power supply pormblems
Posted on Jun 23, 2010
I have a LG LED TV 55LS4500UD that no longer works after a storm. It won't turn on and no standby light. I have pics of the circuit boards. I would like to know which board to replace?
Power Issues Troubleshooting
*NOTE* LG & Vizio TVs must be plugged in for 5 minutes before it will turn on*
1. Inspect ALL Ribbons and connectors. Any tears or bad connections between boards must be replaced FIRST
2. If you have any of these boards, it should be the first board to be replaced
A) T-Con Board - Video Problems (No Video with standby light on, audio but no video, grainy, distorted, or color problems in screen)
B) X or Y Buffer Board (Plasma TVs only) - Standby light is on but no power
C) Backlight Inverter / LED Driver - No Video with standby light on
3. Main Video Board
- Either video or audio does not work (if no T-Con in TV. If audio but no video it is T-Con)
4. Power Board - No power AND standby light does NOT turn on. If standby light is on try other boards above
5. Panel - No power, distorted picture, lines, slow motion, half screen, faded in / out. Panel problems are usually not worth replacing the panel.
Apr 11, 2016 | LG Televison & Video
No color
Does it have a video input? Does it have color when playing a vhs tape or dvd into the video input?
Does the set show the raster lines? Is there any snow showing on the raster?
If the set does not show color with an a/v input either then it is likely the main power supply section feeding the deflection system or the video processing is bad.
RCA sets more than a few years old are not good investments for repairs, unfortunately.
Let me know the answers to the questions above and I can give you a more precise suggestion.
 Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Feb 02, 2008 | JVC AV-27S33 27" TV
Tip
Tv problems lg and vizeo
3. Main Video Board
on May 22, 2015 | LG Televison & Video
I replaced both backlight boards but still having problem with LCD TV...it is too dark and color distortion.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 05, 2015 | LG 42LC2D 42 in. LCD HDTV
Lg tv initialization on screen and not going on
most likely power PCB,( look for those leaky capacitors) could be the mpu , but still requires the power PCB.( check your voltages on the PCB.) Could also be the I/O PCB.
May 08, 2014 | Televison & Video
The stand has been taken off need to put back on LT 3050
LG RD- 14CA30M MODEL TV PICTURE NOT SHOWS WHEN HIT THE TOP OF TV PICTURE COMING,1 OR 2 MINUTS AFTER PICTURE GOESE THAT SHOWS RAINBOW COLORE AUDIO OK,,,SOLUTION PLZ
Aug 20, 2010 | Mitsubishi LT-3050 30 in. HDTV LCD...
50' philips plasma tv has sound but picture is distorted
I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
LG 32LCD LCD TV Problem
It turn out to be a $10 diode on the mainboard, which cost me $100 to have troubleshot and repaired
Jan 19, 2009 | LG 32LC2D Television
Sony trinitron 32 in. pip no video, (raster, with audio)
What you have described there is a classic example of the jungle IC failure. Ic301 Sony p/n 8-752-101-04. A pic with no color, and lines or grainy texture in the picture. Not a project you want to tackle if you don't have the proper soldering equipment or skills. And not a costly one at a good repair shop.. Only real hurdle is getting that heavy monster into the shop. To answer your question, yes what you described there is raster. Even the salt & pepper looking screen with no real decernable image is described as raster. In fact any image generated on the CRT is raster. And yes, these sets are prone to solder joint problems, usually ring cracking in circuits that generate the most heat.
May 20, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
97 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
