Question about Polaroid FLM-2632 Television
Flm-2632 picture fades to black.
Tv powers up fine. but after about 30seconds the pictures flickers a few different colors almost like bad cable connection then fades out completely. it doesn't go to the no input screen it literally goes black.
Posted by websourcerer on
Bud Martin
  • 11,361 Answers
My Samsung TV color fades out after about 30 seconds.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 28, 2014 | Televison & Video
Luxor 40 914 tvb
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Televison & Video
My LCD tv screen becomes scrambled on half of the screen with input from a different source and has reddish colors.
Likely another board is bad--GET IT IN FOR REPAIR UNDER WARRANTY BEFORE NO WARRANTY SITUATION
Apr 01, 2012 | Televison & Video
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
DVD picture is crystal clear, but wavy lines when using cable. Connected a different tv to same cable and picture is fine. internal coby tv to cable connection must be bad?
you can get a standard RF (cable) male connector to AV (the yellow,white and red colored) adapter at radio shack for a few bucks...if it is a internal connection, that will bypass it...you will just be watching cable on AV-1 or wherever you plug it in
Aug 28, 2009 | Coby Televison & Video
Color fading, orangy red, video adjustments don't fix.
if it is a tube type unit you may not find a new tube they are almost extinct ,
also, most tube malfunctions are caused by improper voltage, only a qualified tech should work on the high voltage section of a tube tv,,, it can kill you even if it has Not Been Plugged in for a whole year
re-post with the make and model number for further assistance
Apr 08, 2017 | Televison & Video
Color stream not working
First try different cables for the video. You can use an audio cable for testing. It seems like the green channel is not making a connection. I'm assuming otherwise the set works fine?
Nov 21, 2008 | Toshiba CX32H60 TV
Color fading on Sony could be cable ?
have the cable company come out and check there cable box and picture.
Jan 28, 2008 | Sony KV-27V22 TV
Screen flickers on / off when run through receiver
No solution, but I have the same problem with my Panasonic plamsa TH-50PE700U with a Yamaha RX-V2700 receiver. I don't think the cables are a problem. If I turn the TV on and off about 20 times the system stabilizes until I turn it off.
Sep 03, 2007 | Audio Players & Recorders
Picture Fades
It isn't clear if the picture just loses color or the screen goes blank. If you are just losing color (picture goes to B/W) there is a problem in the color circuit and from your description it could easily be a bad solder connection on the board which decodes the color portion of the picture. If you are capable with a soldering iron and know TV HV safety, unplug the set, and remove the circuit boards and inspect (with a high powered magnifier)and resolder all suspect looking connections on the boards. You could also resolder all the connections which is more work but assures that solder joints are not the problem. If your problem is not solved at this point you are probably going to need a technician to look at it as it could be just about anything and probably would be beyond your expertise. Good luck and be safe.
Jul 12, 2006 | Sony KP-57WS500 57" Rear Projection...
Polaroid FLM-2632 Television Logo
204 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
