Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
Life fitness 9500 is shocking users? help? - Life Fitness 9500HR Next Generation Remanufactured Treadmill
Posted by mike59918 on
Chris Jowsey
    Champion:
  • 208 Answers
Hi, there is a service bulletin for this problem.
1) perform a continuity test on the power cord between the earth pin at the plug and any exposed metalwork of the treadmill (say an exposed bolt). If you get a reading of less than 1ω - that is good. If higher than this, try another part of the treadmill or trace the cause.
2) Ensure the Power outlet has a good ground - Your electrician could verify this for you.
The most common problems are static buildup on the Striding belt caused by users wearing polyester and scuffing their feet as they are running. This causes static buildup which gets discharged through the user when they come into contact with the treadmill frame.
Happy hunting
Posted on Jul 07, 2010
Life fitness thread Mills 9500, unit immobilise by manager
hello dear how are you
you should press exactly in sequence what i tell you
press the speed arrow down three times
then press the stop three times
let me know if you solved it
Oct 06, 2018 | Life Fitness Exercise & Fitness
Life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
Apr 04, 2013 | Life Fitness Crosstrainer, 9100, 9500 Rear...
How do i get the hours info from a life fitness 9500 hr elliptical
go to the MENU, and see the details.
However your must read your instr. manual and see how to enter.
God bless you
Dec 05, 2012 | Life Fitness 9500HR Next Generation...
Finding total mileage and useage hours on a Life Fitness 9500 Treadmill
unfortunately, is NOT possible, Not miles or kms in treadmills.
You have to buy the eagle eye.
God bless you
Oct 07, 2012 | Life Fitness 9500 HR Treadmill Next...
Lifestride 9500 treadmil show noilfy maintenance display
proceed with the instruction manual maintenance, if you do not have go for free download : www. fitness.manualsonline.com or www.iconservice.com
RUN THE software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
May 07, 2012 | Life Fitness Lifestride 9500 Treadmill
I was cleaning life fitness 9500 hr with an acid base cleaner, and control panel is not working any more, buttons do not respond, can turn it on though
I'm sorry to say that using the acid base solution destroyed your function pad and will need to replace. Any clean must be done with simple green or warm gentle soapy water. Contact Life Fitness1-800-351-3737 or Nation Gym Supply 1-800-496-7278 give Model and Serial Numbers. Either company will help you.
May 09, 2010 | Life Fitness 9500HR Next Generation...
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
171 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
gbob59
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
