Yes. Two ways to do it. I would use burst proof hoses first of all (the stainless braided style) I have seen lengths to 12' or couple 2 6 foot hoses with a threaded hose coupling. The drain hose is availible to any cut length at Home Depot or Lowes. Does not have to be the corregated plastic one , but one that is more kink proof the soft vinyl hose. Measure the ID (Inside diameter) to match up. Make sure you support the drain hose over that long distance since the drain water may weigh it down. Good luck!
When draining the coolant, keep in mind
that cats and dogs are attracted by the ethylene glycol antifreeze, and
are quite likely to drink any that is left in an uncovered container or
in puddles on the ground. This will prove fatal in sufficient quantity.
Always drain the coolant into a sealable container. Coolant should be
reused unless it is contaminated or several years old.
Exploded view of the turbocharger-22R-TE engine
Click to Enlarge
Installing air cleaner hose-22R-TE engine
Click to Enlarge
Clip installation-22R-TE engine
Click to Enlarge
To install:
