Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
The lights are blinking and I can not turn on the dishwasher.
Posted by cenzo1011 on
Prakash R
    President:
  • 1,382 Answers
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Posted on Jun 22, 2010
  • k9clubinc Nov 06, 2010
    When my dish washer quit working, the same day that the whole house airconditioner went down, I was sick ! The air turned out to be from a factory defect in the new compressor that I installed last summer , a year ago, with a credit card that I still havn't been able to pay off. So, I was sick ! The flashing light on the touch pad gave me hope though. After finding this web site, and the poast, to press normal-heated dry, three times to reset the touch board. I went home and was so relieved to be able to wash up the dishes, and put away the pile that was sitting there drying themselves from breakfast. You guys really have my thanks for this great service that you do for people. Thank you from the bottom of my heart ! Really ! thanks guys..larry P.
  • frank nowicke Nov 24, 2011
    Thanks, your solution works. Particularly on T-Day!
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Maytag dishwasher MDB8959AWS2 blinks 7 times and will not work, what is the code to reset.
Try the instructions listed at this site. If the problem still occurs after the reset it is usually the heater element that might be faulty.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Dec 25, 2014 | Maytag Dishwashers
BLinking panel lights will not turn off
Specifically what lights are blinking? Do you have the child-lock (control-lock) turned on?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 14, 2014 | Jenn-Air Dishwashers
Dishwasher flash light blinging
Dishwasher lights flashing and blinking usually means some circuit or sensor problem > it will be helpful if you can provide the full dishwasher make and model number and specifically note which lights are blinking or flashing. Also try to turn the mains power connection to dishwasher off and back on to see if there is any difference in behaviour.
Feb 16, 2014 | Dishwashers
Start light keeps blinking
More information is needed. What is the make and model number of your dishwasher?
On most models with the digital display: Blinking "Start/Reset" light. This indicates that the dishwasher has been reset and is in the process of turning off. This light will continue to blink for a time period between 75 to 90 seconds depending on the model.
Dec 19, 2013 | Dishwashers
Clean light blinks, dishwasher won't start,
turn the power off at the breaker for 10 minutes and check it then.
Jun 11, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Green blinking light
If you don't have the manual for your dishwasher to find out why the green light blinks, try to get the model number off your dishwasher from the inside edge and go online to find a website that provides online manuals.
Feb 26, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
