I would recommend using the Dell factory restore DVD. It probably didn't come with your computer (companies save money by not shipping a DVD with the computer). You can order it from Dell and it will probably cost less than $20. Many times the restore function by hitting a special function key at startup becomes corrupt and doesn't work. I'd opt for a new DVD to use.
A number of these machines have a function that can restore to factory settings by pressing one of the special function keys at startup. There is a factory restore partition on the hard drive that keeps this info. So, if on startup you see a message such as "press F11 for restore" or something like that, do it.
Laptop Recovery Instructions If you cant boot into windows
1. Power on the machine 2. At the white ACER BIOS screen, hold the "Alt" key and press the "F10" key
simultaneously to start Acer eRecovery 3. Once eRecovery has loaded, click "Restore to Factory Default Settings" 4. Click "OK" to continue 5. From here, the eRecovery process will update all the data on the C: drive
and restore a fully functional factory image (approximately 10 minutes). 6. Once eRecovery has run, press "OK" to reboot unit
If you can boot into windows
Click "START"
All Programs
Acer/ Packard Bell/ E-machine recovery
Select "Recovery management"
Click "Restore"
Click "Fully restore to factory default"
NB: This process takes about 15 to 20 min
computers dont realy have a factory reset the only reset function that exist is with bios to do this when the unit is first turned on press f12 and it will take you into bios but if you dont know what your doing i would not mess with bios but its your computer
Turn off the system.
Turn on and press Ctrl+F11 immediately. It will take you to the DELL Complete PC restore which will help you restore to factory settings.
look at the screen as soon as the computer boots up. see if there is a function key that says "system restore" .If there is no recovery partition , you are going to have to order a set of disk from emachines. Or use a licensed copy of xp and manually download and install the drivers.
No the restore might not be possible if you don't have the disk.
You might have a restore partition on the hard drive but to access that there is a key combo that might have the Fn key in it. For this you will have to search online or contact the manufacturer
Are you fimilar with system restore function in Windows. Click start>all programs>accessories>system tools>system restore. Go back to a date when the pc was functioning properly, choose date click continue/OK. Sit back and wait until the system recovers. Log in as normal.
Id try this option 1st : Computer Cleaning Information
We did not find any results for Fujitsu > AMILO D-8820 PC Notebook need factory setting down load or cd.
Other searches you may want to try:
One of theses site will have a down load for your computer factory setting or also could find a cd factory settings for your computer.
