Sometimes when you connected Garmin to your computer it will not charge. Garmin won't charge is common issue. We shared easy troubleshooting solution to fix the Garmin won't charge issue.
Let's know the reasons below:
• Faulted USB Cable
• Pending Garmin GPS Map updates
• Damaged or Faulty vehicle power cables
• Device Internal issues
• Damaged Battery, and power jack Issue
Methods to fix Garmin not charging issue:
We have also shared the another Easy Solutions to fix the Garmin won't Charge issue within a minute.. Don't panic when your "Garmin GPS Not Charging".
Try it on a different computer: sometimes the USB connection is simply unable to provide sufficient power on some machines. If that fails then try a different USB lead as yours may be faulty. If the unit charges correctly in the car, then the USB socket on your Garmin is definitely OK.
