SOURCE: Can't read a DVD-R that was produced by Canon DC210 DVD Camcorder
Canon DC210...To finalize the disk, you first probably want to have the AC adapter plugged in even if your camera does not require it in order to access the finalize menu option, as the process can be quite lengthy and use battery power -wouldn't want to run out in the middle of the operation....THEN....Make sure you are in VIEW mode -not record mode...THEN...Press the FUNC button on the side of the camera -you should then notice the FINALIZE option -among others -navigate to the actual finalize command using the joystick, then press it down and let it work its magic - try not to move it until it is finished. After it is finished -it can be removed and will be recognized by a dvd player, recorder or drive that is compatible with this type of disk in the first place, Apparently, this camcorder records video to the .VRO file type -so be sure any video editor/converter/player software on your computer recognizes this file type.
SOURCE: Unable to Finalize Disc/Finalize Option Blacked Out
After spending some time with Canon at 1-800-828-4040 I have found out that there is one small but crucial step missing in their instruction manual on Finalizing the disc. Take battery out and power the camera with the cord plugged into wall socket. Turn camera to the on position and let DVD normalize then when it stops move the on switch downward into the play position. With the viewing window upen you will see thumbnails of the pictures that are on the DVD and a small green light will come on opposite play on the camera. Push function and a menu will come on that says disc operations at the top AT THIS POINT PUSH THE JOYSTICK TO THE RIGHT and you will notice the light move from the right side of the viewing window to the center. Now with the joystick scroll downward until FINALIZE is highlighted even though it is in white, push inward on the set button on joystick and you will get a screen giving you information about how long it will take to finalize and it will ask you if you want to finalize yes or no. Choose yes and it will turn yellow or orangish and will start finalizing. You will also get a progress bar at the bottom as it finalizes. When it is finished finalizing you will note that FINALIZE in the menu has turned black. The one step about pushing the joystick to the right just as soon as you get the menu is crucial. Hope this will spare a lot of people a lot of frustration. I was almost ready to send mine back to the company or junk it.
Forrest
SOURCE: Cannot intialize/finalize mini-DVD in Canon DC210
The way to get it to finalize is like this:
1. turn it on
2. use cord.
3.move the on buttom to mode. it will show the recordings.
4. select a recording
5.press function butom. it will up bring several choices among "menu"
6. slect menu
7. it will give you all the chioces you need to title, finailize, protect and all needed to view the dvd
Any questions,
let me know.
OL
