Question about Sony Cyber-Shot DSC-W5 Digital Camera
I Use a fully charged(more than 14 hrs charged) New Sanyo battery 2700 mAH Ni MH rechargeable on my Sony Cyber Shot DSC-W5 Digital camera, when the power is on the battery display shown fully charged.. but after a few shot (2-3) there is no more power...what the problem? please help..
  • 1 more comment
  • Anonymous Jun 23, 2010
    Its a new batteries before i use i charge the battery for more than 14 hrs...
    Its a new battery. before i use in the camera i charged for more than 14 hrs..then insert it its display fully charged but after a few shot..become completly exhaust and power shut down..plz help..
    Its a new battery before i use i charge it for more than 14 hrs..then insert it to the camera the display shown fully charged but after a few shot the battery completly exhaust and then power shut down..plz help
Anonymous
  • 105 Answers
May be batteries you brought are old try with normal ( not rechargeble ) batteries. it would not last long but you can take atleast 30 to 50 photos. if it works it means new batteries are faulty.this type of problem i never saw in camera.use SANYO harmolattice HR-3UQ batteries.
Posted on Jun 23, 2010
  • Anonymous Jun 24, 2010
    some times new batteries are also faulty
When i turn on my camera the lens gets stuck coming out
Normal batteries it's not working for me!
After i replace standard alkalines with rechargeable NiMH batteries Sony and Varta 2700 Ni-MH it's was working!
Jul 16, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
My camera won't turn on, and if it does its only for brief periods of time
Please replace standard alkalines with rechargeable NiMH batteries Sony or Varta 2700 Ni-MH!
That's was working for me!
Jul 16, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Fail to open ( alimentation maybe )
Jul 16, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Just bought a second hand Canon Powershot SX100 IS.
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Mar 08, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Sony Cyber-shot DSC-W5. Will not turn on.
try diffrent batteries even the ni-mh batteries go bad after so many charges also make sure you have the batteries in the right way
Mar 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Cannot power on to take photos
I found that one has to use their batteries of at least 2100mAh and NI-MH. I recharged my batteries removed the new ordinary alkaline batteries I had put in and BINGO IT WORKED. Just to prove the point I put in another set of Alkaline batteries No good. It must be that NI-MH Batteries rated at 2100mAH have more power (or one can draw more currentat start up) a battery guru could maybe veryify my conclusions. Anyhow try NI-MH batteries and see how you go. Best of luck fredlich
Aug 15, 2008 | Sony Cyber-Shot DSC-P93 Digital Camera
Battery Life Very Low
totally discharge the batteries [by putting them in a torch to tun them right down] the rechagre them fully, If this does not improvethings = the repair djop but be warned it can be pricey - almost new camera time perhaps.
May 21, 2007 | Sony Cyber-Shot DSC-W5 Digital Camera
Power shuts when in camera mode
The user manual would not be of much help. Please try to clean the battery contacts inside the camera. Please use the new fully charged NI-MH accu batteries preferably 2500 maH capacity. If this measures do not provide a cure please contact the nearest Authorized Sony Service. If you need more info please advice.
Apr 10, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Sony Cyber-shot DSC-U10 low battery indication.
possible short circuit that is draining battery at a speed. get your camera tested at some good repair shop,
Jul 02, 2006 | Sony Cyber-Shot DSC-U10 Digital Camera
Sony DSC-P93 battery replacement question
NiMH batteries. You can use the larger mAh AA. It has more capacity and should give you longer service before needing recharge. The battery manufacturers recommend that you do not mix the batteries. i.e. don't use mAh 2100 and mAh 2500 as one set, use all 2100 or all 2500 as one set.
Sep 08, 2005 | Sony Cyber-Shot DSC-P93 Digital Camera
Sony Cyber-Shot DSC-W5 Digital Camera Logo
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sony Camera Expert? Answer questions, earn points and help others
