There may be a fuse on the board, most likely its not a fuse. Check for any loose connections to the board or loose solder joints at the connectors pins on the board.
Getting an Error Code 2 on your dishwasher, means there is something going on with the turbidity sensor. This is the sensor that determines how dirty the water is which in essence determines how long the cycle will run.
What you can try to do is to reset the appliance for 30 minutes. You will do this by cutting the power at the circuit breaker and leaving it off for no less than 30 minutes. Try running the cycle again and if you are still receiving the Error Code 2, I would recommend contacting the manufacturer for further assistance.
Good Afternoon Will, thank you for allowing me to assist you!
How long did you leave the breaker off? It is important to wait roughly ten minutes and then your dishwasher on. If resetting the power does not correct the issue, then it sounds like your dishwasher could possibly be experiencing a communication error with the control board/panel or a potential wiring failure. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Good Afternoon David - When the light is on, the control is
locked and no cycles can be selected or started. To de-select the Control Lock,
press and hold the heat dry key or press down on the lock icon for
approximately twenty seconds. If issue persists, you may reset the dishwasher
by either unplugging it or flipping the household circuit breaker off. Wait
approximately ten minutes and turn the unit back on. The dishwasher should
resume to normal operations.
To
unlock the lock in your LG Dishwasher, with the door open press the SPRAY &
RINSE buttons simultaneously for 15 seconds.Hope this helps...please post back for further assistance.
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
