We have just tried to print an A4 photos on 260gm photo paper and approximately 25mm is the correct colour, then it quickly fades to almost white and in patches ink is completely missing.
You need to specify the paper type when the print dialog box appears.
Heavy glossy paper needs to spend more time in the fuser so that the
toner is fixed.
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Having photographic quality copy prints made will give you far longer life than the original Polaroid. Polaroid colour dyes will shift colours and eventually fade dramatically. New photographic (and some ink jet) prints will last generations without noticeable fading.
Hi Tom,
Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper.
You can use the following media with this feature:
Matte Paper - Heavyweight A3+, A3, A4
Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper)
Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper)
Archival Matte Paper A3+, A3, A4
Watercolor Paper-Radiant White A3+
Velvet Fine Art Paper A3+
Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
The paper you print on is not relevant.
What happens is the green tint is the actual printer delivering all the colours to give a 'composite' black.
On shiny photo paper this is emphasized where as on plain paper the colour is absorbed and shows as intended.
So what can you do?
Move away from black and go for a tint such as sepia.
