Question about Tomtom GO 300 GPS Receiver
Have a TomTom Go 300. Just installed a new map NO MAP FOUND
Have a TomTom Go 300. Just installed a new map and now have "NO MAP FOUND" error
Posted by venner5 on
Anonymous
    New Friend:
Hi when
i go to a nother state or a town i dont know how to find a bank or walmarts or srar bucks my 300 is 4 years old can i up date it
Posted on Jul 10, 2010
Anonymous
    New Friend:
  • 9 Answers
Delete map(s) inside your device and install again.
Posted on Jun 24, 2010
Re install new cards Canada/US
It may be possible that the new card you purchased (assuming it is for a new map) is for a map (version) that is compatible for your TomTom GPS. (It may be more helpful if you indicate the card/map and your TomTom GPS model) If you had purchased the card from TomTom ... contact TomTom for help.
Often, it is easier to buy a new map directly from the tomtom.com website . That way you'll get the "right" map for your TomTom model. After you pay for it, you download the map directly into your GPS (using the HOME application) and activate it. If you have any problem, you can contact TomTom right away and they'll help you to get it done right.
Mar 28, 2014 | Tomtom GO GPS
Map data not found but it is there from the amount of memory taken up
It's likely that your map (data) got corrupted. You can recover by restoring your back-up copy of the map (that you'd previously done via TomTom HOME on your computer).
If you don't have a back-up copy, try using your computer's disk check utility to fix the file system and recover data (from the storage media on your GPS device). Just connect the GPS to your computer, no need to use TomTom HOME, just use the Properties tab and use the Tools to run a disk check (assuming you're using Windows).
If that doesn't work, you may want to purchase & download and install the latest copy of the map from the TomTom website (via HOME).
Aug 24, 2013 | Tomtom GO 300 GPS Receiver
No maps found
When your tom tom comes up with the no maps found error message. There are several causes to the problem.
If you updated your map using the latest map guarantee and then get the error No maps found, make sure you install the latest version of the TomTom application.
Check for the latest application: Connect your navigation device or memory card to your computer and click Update my device in TomTom HOME to check if a new application is available.
You can check the version of your application in TomTom HOME. Connect your device and then click Manage my device and select the Items on my device tab. Expand Applications and then click More info.
Your map may require the latest version of the TomTom application.
Check for the latest application Connect your navigation device or memory card to your computer and click Update my device in TomTom HOME to check if a new application is available.
HOME may not immediately offer the latest application version when installing a downloadable map on a blank memory card. Re-connect your memory card to HOME and check for the latest application by clicking Update my device in HOME. HOME this time offers the latest application for your device. Try Installing maps on a new memory card
You need to also make sure all files are in the right places. Browse the content of your navigation device:
Windows XP: Click Start > My Computer and then double-click the removable drive of your device.
Windows 7 / Windows Vista: Click the Windows start button > Computer and then double-click the removable drive of your device.
Mac OS X: Double-click the desktop icon of your navigation device.
Check the following:
The map folder (e.g. Western_Europe) needs to be located in the root directory of your navigation device or memory card. This means the map folder may not be inside another folder. Before you move the map folder we recommend that you create a manual backup.
The map folder needs to contain at least the following files
cline.dat cname.dat cnode.dat faces.dat mapinfo.dat poi.dat tables.dat tmccodes.dat traffic.dat .meta (map v705 or higher will have/need this file) .meta.dct (map v705 or higher will have/need this file) .pna
If any of these files are missing restore a previously made backup or re-install your map to your device (in TomTom HOME click Add Traffic, Voices, Safety Cameras etc. > Items on my computer).
Hpe this was helpful. Thanks for using fixya.
Jan 26, 2011 | Tomtom ONE GPS Receiver
Tried to install the free map update/upgrade(North America) on my new XL 335-S and now have no maps at all. The install showed an error and now when I try again, I am notified that there is not enough room...
There is this problem with TomTom. Tom do not seem to overwrite the existing map file. So before trying to install the map, you need to delete the folder containing map. Once you have connected your TomTom to the computer, close the TomTom home window. Double click on my computer. You will see the TomTom hard drive as a drive (like you see the CD drive) double click on that . Once the folders of the TomTom hard drive opens, look for a folder named USA_Canada_and_Mexico_P. Right click on it. click properties. Check whether the size of this folder is approximately around 1.3 GB to 1.5 GB. This is just to make sure we have the correct folder. After confirming this is the map folder, copy this folder to your computer for back up purpose. Once you have it safely in your computer, delete this folder from the TomTom hardrive. Go back to TomTom home software. Use the map guarantee to update/Upgrade the new map. You will see this time around the installation completes without a problem.
Apr 23, 2010 | Tomtom ONE XL-S GPS
It says "no maps found"
I had the same problem before on a TomTom GO 730. The free internal memory was too small to hold the updated map so installation failed (the download to PC was OK, the message is misleading).
It's a TomTom software bug to not check on the available free memory properly before the update process is started.
My TomTom device required a new software install from scratch. Remove any excess MP3 or unused voices before you retry the update.
Feb 06, 2010 | Tomtom One XL GPS Receiver
Picture of tomtom on screen ejecting memory card and crossing it with ared cross
this was caused by interrupting a map download recieved instruction from tomtom to install new map and all should be well
Oct 02, 2009 | Tomtom GO 300 GPS Receiver
No map to be found
The map shouuld be accessed from TomTom "HOME" software .
If you dont have tomtom HOME ...........
For the PC or for the MAC , You can download tomtom HOME here >
http://uk.support.tomtom.com/cgi-bin/tomtom_uk.cfg/php/enduser/std_adp.php?p_faqid=7408&p_created=1184659653&p_sid=PmvpQQmj&prod_lvl1=&prod_lvl2=&cat_lvl1=&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjE1LDIxNSZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZG93bmxvYWQgaG9tZQ**&p_li=&p_topview=1
Dec 31, 2008 | Tomtom ONE GPS Receiver
Map on tomtom go 300
The downloaded maps can be copied direct to the SD card or copied to the SD card via USB lead and PC connected through TomTom Home. Once you have the map on your SD card you will need to activate it with your product code number that you obtained when you purchased the map.
Good luck
Sep 01, 2008 | Tomtom GO 300 GPS Receiver
No maps found
I had the same problem how ever after downloading all the software updates and pretty well evey thing that was available on the tomtom home sight suddenly the map was there. It could be a soft ware bug.
Mar 19, 2008 | Tomtom One XL GPS Receiver
OUt of date map
go to www.tomtom.com
download 'tomtom home' to your PC.
this program will allow you to update the OS & let you buy new maps camera warnings etc.
You can buy them in your local stores too.
Dec 18, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
417 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Ekse
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
