Aroma ARC837 20Cup Rice Cooker Logo
Question about Aroma ARC837 20Cup Rice Cooker
How do I turn it on? I pressed brown rice and it is not cooking.
Posted by rochadns on
Anonymous
    New Friend:
First you need to power it ON then select/press the brown rice button. if still no lights are on, then you need to call the warranty support number.
Posted on Feb 22, 2013
2 Related Answers
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: Was using rice cooked for sometime. My cooker is
In the top cover of your rice cooker there is a sensor that controls the cooking circuit. Most of the t\ime what happens is the wire in the hinge area breaks due to the opening and closing of the lid. I even had to repair my own rice cooker by cutting away the damaged wire then soldering a longer new wire in BOTH wires. I also added shrink tubing over the 4 connections on 2 wires.
Posted on Jan 09, 2010
Testimonial: "Thanks for the tip"
Anonymous
  • 1672 Answers
SOURCE: how to set time for cooking brown rice
You have to soak and left the brown rice for 10 to 15 minutes in the water before you cook them or adjust the water level a bit higher!
Posted on Nov 07, 2010
For one cup of brown rice how much water do i use.and for how long do i cook for
Sorry not sure about the cooking time but I am sure google would have the answer.
Brown rice needs more water than white rice. Using 2 cups of brown rice in a rice cooker, fill with water to the 3 cup mark.
My rice cooker not cook rice properly leave some waterand un cook rice. What shuld I do steamer is working good.
Are you maybe putting too much water in. usual amount is equal parts water to rice. Except for brown where you need an extra half cup water to each cup of brown rice. Remove the steamer tray, of course when cooking rice.
1helpful
What is the rice to water ratio on cooking brown rice in wolfgang pucks rice steamer?
Usually you want to put one dose of rice for 2 1/2 dose of rice. Brown or whole grain rice will need a little more water and will need to cook for a little more time. Hope that helps!
How do I cook brown rice in the rice cooker?
I tried it once and it wasn't easy. It appears that the automatic rice makers are calibrated for whit rice. Anyway, I had to add about twice as much water as white rice takes and restarted the cooker once or twice until it was done. It was a failure and I never attempted to cook brown rice in it again.
There may be rice cookers that have a setting and instructions for brown rice, but I've never seen one.
Good luck.
3answers
Tiger rice cooker (model JAT-A55U): Rice is not completely cooked
This one has several options to cook different types of rice, white rice, brown rice, sweet rice.... Press the menu to see the correct setting you need for what type of rice you are cooking before pressing the cook button.
3helpful
HOW DO I COOK BROWN RICE. LOST INSTRUCTION BOOK
The manual is on the site listed below (its the company's website):
http://www.rivalproducts.com/manuals/RCS200_English.pdf
1helpful
2answers
Rice cooker spits rice juice all over counter
I had the same problem when I cooked brown rice in my rice cooker! I found that adding a tablespoon of butter on top of the cooking rice solves the problem. (A friend told me it works when cooking beans in a pot, so I figured it would help with rice too, and it did!)
2helpful
How do I cook brown rice?
yup! there is a different ratio for brown rice.
1 cup brown rice = 2 cups water
hope this helps
11helpful
4answers
Cooking rice
I have a Sunbean Instant Streamer model 4710... I just wash the rice, add it to the bowl and add 1 cup of rice to 2 cups water. I fill the the bottom of the streamer to the max line and turn the steamer to 50 minutes.. The rice comes out great in my streamer this way
Top Aroma Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
ADMIN Andrew
ADMIN Andrew
ray gallant
Are you an Aroma Kitchen Appliances - Other Expert? Answer questions, earn points and help others
