KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
Posted on Jun 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchen aid microwave is locked - KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Chuck
Level 2:
Sergeant:
  • Expert 228 Answers
  • Posted on Jun 21, 2010
 Chuck
Expert
Level 2:
Sergeant:
Answers
228
Questions
0
Helped
78999
Points
573
Touch and hold cancel/off button until unlock appears on the display.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
601
Points
Press and hold both lock and cancel/off until lock disappear on the display.
3 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 20, 2008
SOURCE: KitchenAid KHMS155L 1000 Watts
According to the owner's manual for model KHMS155L:
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound and a lock icon appears on the display. Repeat to unlock and remove the lock icon from display.
You can download the manual here:
http://www.kitchenaid.com/custserv/service.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 04, 2009
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Anonymous
  • 125 Answers
  • Posted on Aug 20, 2009
SOURCE: kitchen aid microwave KHMS155LBL2 showing up
first is it under warrenty? if so take back. if not and you want to fix it yourself: how much did u pay. less than $200. maybe trow it away and buy new one. if u paid more and r fixing it yourself, then unplug it from the wall, wait 60 seconds or more then plug in, check display only. do this and respond for more help.
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
1helpful
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
Microwave - Kitchen Aid KHHS179LSS4 ERROR CODE -
Hello there Jerry
Sorry it took so long getting back to you i just finished moving into my new home and just got my internet today ok ill send you a troubleshooting steps
However this error code usually turn out to be a problem with the controle panel of the microwave and the only fix for these is to replace the part ok i will post the rest of the troubleshooting steps in a following comment ok
Best regards Mike
The Kitchen aid superba oven is locked -- how do I unlock?
Turn the power off at the breaker and then back on again...
heatman101
I'm looking for repair manual for range made by Kitchen Aid
web search-kitchen aid range manuals- or -kitchen.manualsonline.com
1helpful
Kitchen aid microwave KHMS155LBL2 showing up locked and then showing F2. It keeps beeping. Now it won't let you do anything.
10helpful
2helpful
3answers
GE Microwave oven
Since this was not replied to, I will called it closed.
Please do not rate this unless you still need a solution and will reply back first with the information I requested.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
