Hi
Thanks for using FixYa. F1
error means that the flood switch has been activated. You’ll need to reset it by powering off the
breaker or by unplugging the unit from the power socket and mains for more than
five minutes. Please check that there is no blockage in the drain hose and it
is not raised higher otherwise the water will run back to the dishwasher. Also
perform the following procedure---
Please do rate the solution if the issue is resolved or
else revert for further assistance.
Thanks
Rylee
SOURCE: Dishwasher "F1 and a small wrench symbol" blinks continuously
The unit has a leak causing floor sensor activated.
1- Unplug power cord.
2- Pull oull half way the drawer so an access from the bottom left could be obtained.
3- Use Paper towel or small towel to dry out the water on the bottom housing.
4- Wait for 48 hour so the sensor can be dry out.
Plug in the power cord. The unit will act as normal.
Your problem is solved.
However you can't operate since you know you have a leak problem. Let me know how it in progress and you decide to call service to fix it or I can guide you to fix it. Good luck.
SOURCE: Flashes F1 and a wrench symbol... water doesn't
Assuming you are getting the F1 error in both drawers.
This means there is water at the base of the housing under the bottom drawer.
Turn power off and take the drawer out. You will have to pull out the plastic pins on either side and get the front cover off. This will enable you to pull the drawer out from the slide bar for better access. Use towels and hair dryer to get rid of all the water. The flood switch is mounted on the power board. Use hair dryer to dry this out.
Put everthing back and turn power on.
Post a comment if this is not fixed or the F1 is only coming in one of the drawers.
Please rate this solution.
SOURCE: Cannnot turn off or move
The F1 code indicates an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose.
The F1 fault could
be from your lid actuators not working properly or the lid seal needs to
be replaced or check ur flood sensor it located at the back under a
black plastic cover, the sensor is the little add on at the left. make
sure u turn off power before touching anything
Hope helps.
