Refrigerators Logo
Anonymous Posted on Jun 21, 2010
A friend just gave me their old refrigerator that they had in their garage. got it home, the freezer is freezing at -02...the frig is barely above the spoilage mark on the thermometer. what could be wrong?
Chuck
Level 2:
Sergeant:
  • Expert 228 Answers
  • Posted on Jun 21, 2010
 Chuck
Expert
Level 2:
Sergeant:
Answers
228
Questions
0
Helped
79084
Points
573
SInce the freezer is cold and the fridge is warm it's a air flow problem. Check to see why the fan in the back of the freezer isn't turning.
Testimonial: "makes sence..water to ice maker is leaking inside...i shut it off but probably not before it has frozen up the fan. will check that. thanks!!"
1helpful
Have extra older Frig in th garage Mod 596.72232200
Sounds like a intermittent problem with the defrost timer. Sometimes they get stuck. Check continuity of the defrost heater and defrost thermostat. If both are good then replace the defrost timer, that should solve the problem.
Kenmore sidebyside 106 is freezing wide open on freezer side and barely cooling on frig side. there is ice in venting on the frig side
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
The engine is still running, but the frig is warm a friend turned the timer and the freezer is freezing now, but the frig is still warm. Do I need a new timer?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
I have an Amana side by side frig and the freezer is not keeping ice cream cold. The refrigerator side seems fine. The freezer side is set to 7 but it no longer clicks like it used to when you turn the...
If you do not have guages (freon) and have a licens to proforme this type of work you will need to have someone qualified in this area to varify.You can call sears home repair @ 800 469-4663
Refrigerator light is on but it's not getting cold
Yes, I can help you. (If you like).But you will need to answer a few questions. For example was the freezer and refrigerator doors left closed for all that time with out allowing the moisture inside to escape and not cause the controls to rust or short out. Let me know and rate me if I am helpful, Thanks, Sea Breeze
No air getting to fridge, freezer barely freezing
Sounds like the circulating fan behind the rear panel of the freezer is wearing out. When the freezer/refrigerator fan starts to wear out the rpms reduce to a point where it will keep the freezer cold but not the frig. the total minimum estimated cost to repair this problem is around $300.00 parts and labor
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Fridge freezer not working but lights on
Our new 10 day old top frig/bottom freezer stopped freezing, then the top refrigerator stopped cooling, but the light was working and you could hear some motor running and an occasional "clicking" sound. One internet blogger adsvised unpluging the appliance for 1/2 hour. Another advised 2 hours. Then plug in the appliance and see if it started cooling/freezing again. Our experience = nothing. We called the repair folk and the new frig/freezer had a failed compressor and a broken timer!! We were not thrilled. Suprisingly the store we bought the ap[pliance from gave us a $50 gift card to compensate for the lost food. They didn't have to do that - so ask for it; can't hurt.
Whirlpool Freezer doesn't freeze?
insulated or not, garages are generally too cold for new energy efficient frigs to operate. ambient temp needs to be above 60 to work efficiently.
Top Refrigerators Experts
vince
Johnny 1000
