Question about Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728
Schlage deadbolt will not unlock even with the use of a key?
New Schlage hardware was installed 6 months ago. Door now remains in locked position (frozen) for a week. Hardware is the type that is locked by key at the door's exterior, but can be manually unlocked from inside the house. The manual lever inside moves back and fro, but will not unlock deadbolt???
knite1
    New Friend:
  • 16 Answers
It sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Posted on Jun 21, 2010
Testimonial: "I will try your suggetion. Thank you."
SSHAAS
    New Friend:
Have the same problem, with two new deadbolts. a small piece of metal that holds the flat bar that disengages the lock keeps falling out or breaking. cheap design going back to home depot replace again.
Posted on Jun 20, 2011
We recently had a new door installed. It had a schlage lock. Can we program our other Schlage door locks so that one key fits all door? The locks are standard, not keypad.
Any locksmith can do it,BUT- if you go to hardware store you can find locks that have a number on the front of the box that says something like 'TypeA, or Type B' If you purchase the same lock type with the same number or letter, they will all use the same keys included. It's much cheaper than a locksmith.
May 06, 2017 | Schlage Locks & Locksmithing
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
Need schlage deadlatch part replacement
Go to this link: http://www.schlage.com/en/home/products/products-hardware-accessories.html
Browse door hardware parts and decorative entry door accessories from Schlage.
Locksmith Hamburg NY 716 646 8383 24 Hour Locksmith In Hamburg NY
Aug 08, 2013 | Schlage Camelot Deadbolt Keypad, Satin...
I need something to help me put the insides back together.
If it a Schlage door knob. We have installation guides on our website at http://www.factorylocks.com. Here is a link to knob installation. Schlage F Series Installation Instructions for Knobs and Lever
I hope this helps. Leslie, factorylocks.com
Jan 27, 2013 | Ace Hardware Ace Ball Knob Entry Lock in...
When I punch in my code for my Schlage FE595, the code is accepted and the schlage key blinks, however, it does not allow for the unlocking or for me to open the door. Also, when I set my door from the...
You did not indicate whether this is a new installation that you are having difficulty with,but I'm going to assume that it is.
I'm going to direct you to a web page that has a wealth of information for the Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
This page has links to the PDF file of the installation instructions, which you should already have in your possession:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
Also, there are two videos that may be helpful in troubleshooting your problem:
Installing your FE 595 Keypad Entry Lock video:
And, Programming Your FE 595 Keypad Entry Lock:
The reason that I think it's a good idea to review these two videos is that again, assuming this is a new installation, is that you may spot a mistake in the initial installation process.
Was the "Thumbturn" in the proper position when the inside plate was installed? (Shown at the 5 minute mark of the installation video)
Also to be found on the Service Support page link is a link to Schlage's Service & Support
which will allow you to contact Schlage if the problem remains unresolved after reviewing your installation.
I hope this helped. Good luck!
May 20, 2011 | Schlage FE595-PLY-FLA FE595PLY620FLA...
I have a two month old Schlage door lock recently I went to get a new copy of Schlage keys. I tried it one time it work and a week pass suddenly my new keys doesn't work and even the original key, it...
Hello My name is Lori and I work at Schlage Customer Service. If this is not a Schlage Key it may be possible that they did not cut the key to the correct code. Look on your key for the 5-digit key code and make sure the keys align up exactly - the keys also should be the same width. Also when you install this B362 you should install it with the katch extended and the keys out of the cylinder. Try some of these tips and if you still need help - please feel free to call us at Schlage Customer Service: 1-888-805-9837 Good Luck!
May 13, 2011 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Just installed a Schlage secureKey deadbolt. The key goes in the keyhole but won't turn. The inside works fine - locks and unlocks.
the first thing to check is to take the hardware off the door and check the lock cylinder with the key and make sure the key works the cylinder,, lots of times the tail piece is in the wrong position and will not allow the lock to turn. also - sometimes the latch and the lock are not lined up and bind, preventing the cylinder from turning.
but maybe the cyclinder itself is keyed wrong and if you take it back to the store where you bought it you should be able to swap it out for one that works,, install that one and all should be good.
c...
Jan 19, 2011 | Kwikset Professional Door Lock...
Schlage deadbolt installed about a month ago. The key will not turn the lock from inside but will from outside. Any suggestions?
my guess is that during installation the inside lock cylinders were 1/2 or a full rotation more in one direction than the outside cylinders. remove it from the door, assemble it and try it without installing it. If it doesn;'t work, take it back. If it's old, oil it. if that doesn't work- toss it- you've spent an hour on a $15 item.
Sep 24, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
New schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
Jun 24, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Schlage electronic keypad lock doesn't work
I have the same/similar problem. I called the company 888 number. The customer rep promised to send me a new one. good luck
Apr 07, 2009 | Schlage BE365-PLY BE365PLY626 Satin...
Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728 Logo
4,558 people viewed this question
Top Schlage Measuring Tools & Sensors Experts
Michael Thomas
Michael Thomas
Mike
Tom Weglarz
Tom Weglarz
Level 1 Expert
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
