Question about Lite On LightScribe (HP640VI) (HP640VI) Burner
I have hp dvd840e super multi dvd writer with lightscribe and double layer burner....i use the 8,5 GB but when i record a move lets say for 2 hours im not getting it all....how do i make go into the 4 hours mode
Posted by judyann32091 on
4 Related Answers
Anonymous
SOURCE: software problem
Nero needs to be uninstalled (using Nero Clean Tool) and then reinstalled after you have added a new lightscribe DVD drive. To correctly uninstall Nero go to Nero website to download Clean Tool application specific to your version of Nero. http://www.nero.com/nero7/enu/Clean_Tools.html
Posted on Sep 22, 2007
Anonymous
  • 12 Answers
SOURCE: Won't Recognize Blank Maxell DVD+R Disks that I Try to Burn!
sounds like your loose 4 prong may have shorted the burner drive on a power on- it may just be that simple- it died...
Posted on Jan 16, 2008
Anonymous
SOURCE: super multi dvd writer gsa-h55n
I have a problem too, it won't read cd's
Posted on Jan 24, 2008
Anonymous
SOURCE: Lite On LH-20A1H DVD RW burner refuses to recognize DL disks?
I have an LH-20A1S, & I am using Roxio Easy CD
Creator 6; Yes, I know there are newer versions, but they all ****! Anyway, it USED to work just fine in recognizing DL DVD's W/the updates from Roxio's site. & now there is no option there for this size (8.5)w/in the actual Creator prog. Is it the drive? This JUST started happening recently. Any clue if it IS the drive? & if so, any idea what caused this? I've always used Lite-On's & have NEVER had this sort of prob before! & of course it is out of warranty, & a discontinued model to boot! standar DVD drives are real cheap inprice these days, but STILL I do't wanna have to buy an new one if I can 'fix' it. BTW, I have updated the latest firmware for this drive from Lite-On's site too, & it didn't resolve this issue either!
__ERIC
Posted on Nov 22, 2009
My dvd not writing but read
There can be several reasons for that. Try to use Nero software if you are using LG SUITE. Also the DVD write speed and format has to match that of your writer. Ate you copying another DVD or writing data or edited media such as movie video or music files? Check compliance format.
Jul 11, 2013 | LG SecurDisc 20x Internal Double-Layer DVD...
Im having trouble with my drives it wont read the cd or burn the cd or dvd
Hello there,
If your LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe does not read disc, burn cds or dvd, then it means there is a problem with the lens of the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe.
You will have to replace the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe or have the lens replaced.
Be sure not to use the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe to watch movies as that weakens the lens easily.
Hope this helped.
Goodluck
Elect_Comp
Aug 09, 2011 | LG SecurDisc 20x Internal Double-Layer DVD...
Can i write double layer dvd on my lg super multi dvd writer (GH22NP20)
The drive's name tells us that you can write a double layer DVD just fine. Have you tried it ou yet? please update me of the proceedings so I can be of better help.
Dec 07, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
Lg writer not work
Is this device showing in Device manager if so try Nero burning room for writing .Also try checking by reading a normal CD
Jun 13, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
    Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
    Lightscribe means you can create a label on a disk.
    Check these Links fro more information:
    http://en.wikipedia.org/wiki/LightScribe
    http://www.lightscribe.com/gettingstarted/index.aspx
    Good Luck!!!!!!!!!!!!!!
    Sep 18, 2009 | HP Pavilion dv1000 Notebook
    Dvd
    Compaq information can be found by doing a product search on either the Compaq website or the HP website.
    The model number you have given is not enough to narrow down your machine. I have included a few of the CQ60 series machines I found with a simple search. In both cases the answer is "yes you do".
    CQ60-228US version
    Multimedia Drive
    SuperMulti 8X DVD±R/RW with Double Layer Support
    CQ60-222EZ version
    Multimedia Drive Lightscribe Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
    You can find the rest of your model number by searching the label under your machine. Then search the HP or Compaq site to find all your specs, updates etc.
    Good luck and have fun with it.
    Sep 01, 2009 | Compaq Computers & Internet
    Dvd writer for toshiba satellite pro
    HP dvd1040i 20x Super Multiformat DVD Writer
    Price: $69.99
      Internal drive (double layer)
     Write speed: 8x double layer, 20x DVD±R, 48x CD-R
    Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
    Read speed: 16x DVD-ROM; 48x CD-ROM
    Lightscribe disc-labeling technology
    one-year limited warranty....
    HP dvd1040e 20x Super Multi DVD Writer
    External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Lite On LightScribe (HP640VI) (HP640VI) Burner Logo
    Top Lite On Computers & Internet Experts
    Vernon Taylor
    ray gallant
    Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
