Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
Posted on Jun 20, 2010
What chemicals do I use to startt up the pool for the first time ( 5050 gals.-- Intex Rectangular Ultra frame pool ) Krystal Klear Model # 635T Filter pump. I ordered a saltwater system but I Don't think that is whaat I got.
avionik99
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Jun 25, 2010
avionik99
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
14066
Points
47
You will need a test kit to maintain the levels correctly. But I just filled a 16ft round (5000 gals) and use 6ea 1 inch hth tablets every 2 days
I have a Intex above ground Pool 18 feet by 9 and 52 inches deep. How do I over winter this pool?
no you cant keep an above ground pool full water unless you live in a warm climate area that dont feeze
What would be the best automatic pool cleaner for intex 18 x 48 easy set
try to get the vacuum that works with the garden hose they work ok for the small pools
I have 18 feet by 9 feet metal frame pool and the water 3/4 up but the poles on the side are bending in how do I fix this?
Sounds like the poles need to be replaced. The pool will probably need to be drained to take the strain off the sides of the pool.
How to convert from 637R pump to 635T pump? The inlet & outlet opening of the pool are too small
Hi I have a 637r pump that had no hoses when the pool was given to me so I was just gonna buy a 635t pump that has everything included for 50$ bucks can I use that pump in replace of a 637r pump?
First year with 18' by 52" pool with the krystal Klear pump is there any other chemicals beside salt I need to add to the pool Bromide etc
Thank you for posting your question here on Fixya.com.
Chlorine generators cause pH to rise over time. You will need to balance the pH from time to time using acid. Use a test kit to determine when the correct time is to treat the water. Generally speaking, once the pH is getting up near 7.8 you should add enough acid to drop it back to about 7.2 - 7.4.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
What is the best model filter pump for an 18' X 48" intex metal frame pool?
No doubt about it the Intex Krystal Clear Deluxe Saltwater System & Filter Pump. No more chemicals to add and no more money to spend. Just buy salt. Could not be easier. I own one myself. http://www.intexcorp.com/saltwater_02.html
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
