Question about Phylrich Swan fully adjustable Shower Head with flange K800-014
My 8.5kw gainsbrough shower is heating up but
My 8.5kw gainsbrough shower is heating up but water dosent come out the shower.it does for a start then stops but is does sounds like it want to come out
Posted by moorehain511 on
Rich Florenzen
    Sergeant:
  • 333 Answers
Take the shower head off and check for obstructions then turn water on to check the flow through the shower pipewith head off. Most shower heads now have a flow restrictor in them that you can remove should be right there inside by the threads
Posted on Jun 22, 2010
Leaky shower head
You need a replacement cartridge or faucet washer on that shower control
Jan 08, 2018 | Moen Home
I have a bristan 8.5kw electric shower, temp fluctuated to very hot, then to very cold. Now only cold. I had a combi boiler fitted now the shower seems broken, does this have any relevance to the flu
Changing the heating system will not affect an electric shower as it is run from the cold water supply,sound like the temp thermostat has blown ,contact bristan or there website to get a replacement thermostat,telling them which model electric showrr you have.
Sep 13, 2017 | Home
Hot water at showers is intermitent while shower is on
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/Crossover.html
Set timer so pump is off when shower time arrives
Check for crossover
Check if installation is correct... is the crossover valve installed correctly?
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 02, 2012 | Grundfos Comfort System Recirculator ...
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Hello I have a Heatstore aqua plus shower Model number 53594030. The overheating light is on and only cold water is coming out the shower has not been used for over 24hrs now and is still not working....
Hi
Im Rossouw
I would think if its a electrical mixer for ur shower with its own thermostat that that will be the couse . undo the cuver plate and the tap meganisem to get to the thermostart, put it on 0 and then 60 degres put everything back and c if it dident just jam. if dat dosent work the thermostat may be broken
plz rate my solusion if u have an electrick shower
Jun 17, 2010 | Home
Lack of Hot water pressure
If its a tap refurde to, remove the head at the front of the tap and clean out the filter in front, if the houses warm water has low presure u must find ur presure redusing velve located on main cold feed to geyser and clean the cartrage out revit and ur presure must then be vine , let me know if that dosent help
May 28, 2010 | Danze & Single Handle Tub And Shower...
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
how on earth is this related to gaming consoles or PS3 ??
Please post under correct sections next time.
Anyways, it looks like a common problem for the Triton Shower, and it might cost you some $90 to fix it.
http://www.comparestoreprices.co.uk/showers/triton-martinique-10-5kw.asp
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Heating Water Speed
Approximately 10 seconds instantaneous heat.
Aug 27, 2008 | Dynasty Hardware Pacific Shower Basket or...
Phylrich Swan fully adjustable Shower Head with flange K800-014 Logo
126 people viewed this question
Top Phylrich Home Experts
john h
Tom Chichester
Are you a Phylrich Home Expert? Answer questions, earn points and help others
