Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother MFC-440CN unable to print after paper jam. while printing. I have removed the paper jam and I get a message stating "unable to print 50." I have asked for a description of parts I'm supposed to work with in order to fix my problem and I am not getting an answer. So far I have not gotten the correct help and am very frustated and am ready to give up.
richie46
    Top Expert:
  • Brother Master
  • 12,962 Answers
Reset the printer electronics and try then. Might also want to reinstall the driver.
Posted on Sep 24, 2017
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: error messages
I can't help directly but if you go here to the (Australian) support site
http://www.brother.com.au/customersupport/customersupport.asp
you may find your answer.
Note You may need to contact them direct to get your answer.
Good luck.
Posted on May 11, 2008
Anonymous
SOURCE: I had a paper jam
i saw a solution from mix-it-up, he said machine error 50 means this plastic strip that runs under the printer head is not straight anymore. he said the printer head uses the strip as a guide to determine its position along the printer head track. it's possible that it got caught underneath the printer head during the paper jam. i have a picture here of the strip http://img168.imageshack.us/my.php?image=encoderstripdh1.jpg. and i made a pdf slideshow of how i dissembled the top of my mfc-420cn. http://www.sendspace.com/file/ktvhfe. you only have to follow my slideshow up to where the printer body cover is removed until u see the plastic strip. just move it around until it's no longer bumped or pushed by other moving parts. the design should be similar to the 440cn.
Posted on May 12, 2008
Anonymous
SOURCE: Error message 50
Confirm Success on a 440CN
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees
2) make a note of where each connector goes
3) release the Ribbon and 3 Multicore cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees.
4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.
5) Remove front panel by disconnecting ribbon and wireing on both sides.
6) Remove 6 Screws (2 on back, three at front and one middle right
7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.
8) Re-Seat Encoder Strip into guide. (The Transparent strip)
9) Re-assemble in reverse and Hey Presto.
All Cured. Hopefully!
Posted on Aug 04, 2008
Anonymous
SOURCE: "Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Posted on Aug 28, 2008
Anonymous
congrats! You just bought yourself a brand new printer! I just phoned the company and apparently if you have a teeny tiny paper jam and a Unable to print 50 pops up ... you just bought yourself a new machine, that particular message means your machine was damaged thru the course of your paper jam. The average cost an hour to fix it is $85 so its better to just buy a new one.. What a piece of ****. :-(
Posted on Oct 07, 2008
"UNABLE TO PRINT 50" appears
Error: -------- Unable to Print XX
Problem: ------------ The machine has a mechanical problem. -OR- A foreign objects such as a clip or ripped paper is in the machine.
Solution: ------------- Open the scanner cover and remove any foreign objects inside the machine. If the error message continues, do one of the following: ?? (MFC-440CN only) See Transferring your faxes or Fax Journal report on page 139 before disconnecting the machine so you will not lose any important messages. Then, disconnect the machine from the power for several minutes and then reconnect it. ??
May 22, 2011 | Brother MultiFunction Center MFC-440CN...
UInable to print 50
check
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000090/faq002490_000.html?reg=us&c=us&lang=en&prod=mfc845cw_us
Apr 19, 2010 | Brother MultiFunction Center MFC-440CN...
Had a paper jam. Paper was removed. It will not print. It keeps coming up with "unable to print 50" How do I get it to clear that off the screen?
hey... most probably some the paper jam has caused some hardware disruption... u need to remove everything removable and again set it up...
Apr 04, 2010 | Brother MultiFunction Center MFC-440CN...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have the same problem. Most people i asked about it said it is a mechanical problem. It's better to bring it to a brother service center near you.
Feb 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
I had a paper jam in my brother MFC-440CN and now that I have removed the jam the is an error message Unable to Print 50!
May 01, 2008 | Brother Office Equipment & Supplies
Brother MFC-5440CN All-In-One InkJet Printer Logo
138 people viewed this question
Norman  J Weimar Jr
Norman J Weimar Jr
k24674
