SOURCE: Setup DIR-655 w/ Westell 6100 USB DSL Modem
First check if your computer can get on the modem with an Ethernet ( This is to find out if your router will work with your modem) If you cannot get on give your ISP a call to have them configure the modem for Ethernet connection. If you do get on then connect the router to the modem and your computer to the router. You can run the CD for the router or do the connection manually.
SOURCE: VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
SOURCE: Avaya VPN phone behind a DIR-655
- Logon to the configuration page of the router
- Select Firewall Settings at the left side
- Uncheck the boxes under Application Gateway Level at the bottom part
- And Click on Save Settings at the top.
SOURCE: My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
SOURCE: CAN NOT GET INTERNET FROM DIR-655 TO NS7000S
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
