I have Kitchenaid Combination wall Oven and Microwave Model #KEMS308SSS and my microwave runs fine but dose not heat any thing and starts cooling for few mins
KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
When it shows a door error and won't start, that's usually a door switch or door switch mount. My help file on door switches is here.
BUT - assuming your model is the KEMS308SSS01,02,03,04, or 05, it is probably the type that has the overdesigned door sensor circuit, as shown in the diagram below:
In this case, the other likely culprits (besides the door switch) are the 20A fuse, the 15A fuse, the "cavity TOD ("thermal overload device" - thermal cutout / thermostat) and the magnetron TOD.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
It also contains the diagram above.
There's a YouTube video
available showing how to remove a typical over the range control panel assembly
in under 5 minutes.
Accessing the oven cavity TOD for testing and possible replacement will require you to
remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can
download Kitchenaid / Whirlpool owner's manuals and installation
instructions here.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
Does not heat food means a problem on magnetron tube and fuse blown in high voltage area. Have it replaced and it will heat again. I hope I answer your problem.
It sounds like there may be a blown fuse. The back of the mw oven will have to be removed to check. Some ovens only have a thermal fuse and not a traditional glass fuse. If that is the case you should call a technician to repair it unless you know how to use a soldering iron.
