I have a 2007 VN 900 bike has approx 11500 miles on it and was running excellent. Rode the bike 1 day it was dead the next, replaced the battery with a new one and the bike fired right up rode again then stopped and the new battery was dead any thoughts???
Sounds like water / oil emulsification. Is your bike water cooled or air cooled? If it's water cooled then you may have a gasket leak. If it's air cooled then you may not be riding the bike enough to get a good temp up inside the engine which would drive off the condensation inside the crank case / sump thereby leading to the emulsification. You say you rode an easy mile - certainly that's not enough to get the temp up enough to drive off the water. Was the bike running ok? Was it accelerating and braking ok? If so then try a cautious longer run and keep an eye on your levels. If in doubt consult a bike shop.
The stator is probably it..I had the same problem...After you change it the bike will run so much better. That's why it ran good with the new battery...Then it started draining it..It takes a special tool to get it out..
1. Depending on what you mean by holding the charge.
2. As far I can tell, your battery have enough power to start the bike once or twice but then the charge is gone meaning the battery still have poer but the cranking power is below the needed amount.
3. Try take the bike to a battery shop, have them check the battery condition and the same time how well your bike recharging system.
4. If your charging system is good then just replace the battery.
Cheers
Had a simuliar problem, Bike would have a total shutdown a High Temps/Low Speeds/High RPMs. Everything would reset itself after appox 2 minutes. Everything would shutdown Electric and engine.
2 Harley dealers spent 75 hours diagnosing it, dealer could not reproduce it. Last repair was to replace battery cables. Seems to have fixed it. Have ridden 15oo miles since repair. Problem reacurred once last time I rode. Again complete shutdown bike restored after 2 minutes. Did not happen again the rest of the day over 200 miles
So is the battery...ignition needs "X" amount of Volts to run the ignition, the BANG you heard was the engine pre-igniting a fuel mixture in the combustion chamber - because the ignition didn't have enough juice to fire the plug...but the HEAT of the engine DID! Replace the battery with one from WalMart and Ride! Good Luck
