Vulcan quasar elite heater 2400w, trying to find operating instructions
  • Anonymous Jun 20, 2010
    82E series model 8215 2400w quasar elite heater
Jyackle5
  • 8,197 Answers
May I get the model # so I can get you the right manual
Posted on Jun 20, 2010
Testimonial: "fast reply thank you"
Complete cover or fascia for vulcan quasar wall Heater console model
Contact Authorized Service Center or Authorized Dealer.
Mar 29, 2014 | Heating & Cooling
Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Oct 05, 2009 | Heating & Cooling
Vulcan Quasar 40 air issue
Hi the problem you have is your heater is cutting out due to the over temp switch getting to hot the reason for this is that your fan is not working thus not enough air flow is getting through the heat exchanger to keep it cool
your heater is designed to not exceed a certain temprature so as not to become a fire risk
to solve your problem you will need to replace your fan
this will solves your problem
Jul 27, 2009 | Heating & Cooling
No power is there a fuse or cut off switch on a Vulcan Quasar Elite G Series HEATER
Not sure wot series mine is, but has 2 thermal, non resetable fuses in it. They are plastic cased (brown) with 2 spade type terminals. You can check them with the power off if you are not confident with the mains.
Make sure it is unplugged. Pull one of the spade clips off the terminal and then check it for continuity.
Jun 06, 2009 | Sunbeam Heating & Cooling
Vulcan quasar 40 shut down when fan starts up
Replace the fan thermal switch located at the top of the heat exchanger. Unplug the power first as the switch is 240V.
Available from any plumbing trade shops e.g. Reece & Tradelink
Jun 03, 2009 | Heating & Cooling
Vulcan quasar elite heater does not display led readout or any lights when plugged into power point the point and switched on.
this is not an air conditioner but a fan forced heater. The control unit has died and a replacement is over $170.00 !! It's going to be recycled.
Jul 23, 2008 | Heating & Cooling
Heating & Cooling Logo
1,814 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
