Question about Panasonic VIERA TH-42PX80B 42 in. Plasma TV
Why is the power indicator light flashing and can't turn on my panasonic viera plasma tv
Posted by dougandli779 on
Elizar Murro
    Sergeant:
    Champion:
  • 310 Answers
Good day maybe the power board has a defect or in the main board.this cause not to osolate
Posted on Jun 20, 2010
5 Related Answers
Anonymous
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
hi there, have the same kind of problem twice so far after was bought for me as x-mas present (although my viera isnt plasma, its an LCD TX-32LMD70A)..
I Pulled out the mains plug for about 10-20 seconds and then plugged back in (power button at top was pushed in, in the on position, so when the power was on, the tv just goes straight on). It then worked.
i would however like to know why this happens ( i really hope this isnt a hardware problem, as like many others... its only months old!!)
hope this helps
Posted on Apr 27, 2008
ikebert
ikebert
  • 47 Answers
SOURCE: After a momentary power outage Panasonic LCD TV has a flashing red light and will not turn on.
Try using a different outlet, the outlet or the tv may have been damaged in the surge. In the case of the tv contact the manufacturer and see if it's still under warranty. There may also be a way to 'reset' the tv by holding the power button down, try looking in the manual or calling customer support. In the future use a surge protector, many of today's electronics are still sensitive to power surges, older tv's were more resilliant than today's in this regard.
Posted on May 30, 2009
djchillsnyc
charlie rodriguez
  • 152 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Turned Panasonic Viera Plasma tv
Red light flashing indicates some hardware/ circuit board failure in tv, please count how many times red light flashing after long pause as it is an error code that has info about specific section failure in tv.
Let me know how many times red light is flashing in this Panasonic TH-42PX60 tv to provide you helpful info to solve this issue.
Thanks.
Posted on Jan 19, 2011
OLUWASEUN SANYADE
  • 184 Answers
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Posted on Aug 01, 2011
Red led power light comes on and flashes 10x. TV will not turn on. What is the problem
Its a error code and usually indicates power supply or something loading that down.
Dec 12, 2012 | Panasonic VIERA TC-P42G25 42-Inch 1080p...
Panasonic viera th-p42g10a plasma tv has flashing red led light
The number of flashes is indicating a specific error. If you let me know how many times the light is blinking I will let you know whats most likliy causeing the issue. Reply to this same post for assistance.
Nov 09, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma th42pz85u blinking light 10 times
This is the error code, indicating a failure inside the board. Might need attention by a qualified service technician.
Jul 30, 2012 | Panasonic Viera TH-46PZ85U Plasma TV
Plasma tv picture not coming on and power light flashing
Yes, you have power supply issue.
the power on circuit is malfunctioning and the flashes is the indication that the voltage levels for the power on regulation is not correct therefore shut down to protect the circuit from further damage. You TV unit needs servicing by an plasma TV specialist.
Also check to see if you do not have the TV in sleep or hibernation mode.
Apr 22, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Panasonic VIERA TH-42PX80B 42 in. Plasma TV Logo
414 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
