If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
Here is how to change the screensaver to Word of the Day.
Click on the Apple icon at the very top right of your screen and select System Preferences. The System Preferences window will open and you will see rows of icons. Click on the Desktop & Screen Saver icon. In the next screen, click on the Screen Saver tab. Now you will see a list of different type of screen savers. Scroll down to the bottom and select Word of the Day. Close the System Preferences windows and now your screen saver should be set to Word of the Day.
In the picture there is a check box labeled "overscan" Uncheck it. If that doesn't work... What input are you using? This can also happen with the incorrect DVI or HDMI to M1-D adapter. If you are using the M1-D computer input try using the composite input. If you are using the computer with a computer source try changing to the external monitor screen resolution or aspect ratio.
words at top left corner have same word under it in red also on bottom of screen have seen were changing ic;s part# stk392-110 will solve problem if so what are ic;s
sure sounds like convergance problem http://www.partstore.com/Part/Samsung/ Convergence amp ic bad http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html http://www.hdtvoice.com/voice/showthread.php?t=28929
