I am having slow connection speeds. I called my ISP and they say there is no problem on their end and they are not doing work on my lines at all. I use programs that require high speed connections but I have gone up to 2000ms ping times. once in a while it mentions DNS problems and MTU not being high enough.
Check your configuration on your PC, see if it is pointing on a DNS that was previously identified. Make sure it is in automatic. also check your router as well as the signal strength. I suggest don't use the router and directly connect your computer to the internet connection just to check the speed and compare. if it is ok then your router is your problem. check its configuration and set it properly.
