Follow these steps when you are facing "disc wont read" problem
Step 1: Remove the disc from the system.
Step 2: Use a cloth to clean in small circles around the disc (not in a big circle going around the disc). Use DVD or CD disc cleaner if available. If you use cleaner, use a different dry cloth to clean the disc no more than three minutes after application.
Step 3: Verify that there are no disc-destroying marks on the disc. Deep scratches and chips in the middle of the disc can render a disc inoperable.As your Playstation 3 is used more and more, the lens that reads Blue-ray discs can become dirty. This will lead to discs skipping or not being read by the console. If you find this is happening on your Blue-ray discs, either movies or games, you may need to have your console cleaned. Be careful when attempting any sort of cleaning of your console, as improper handling will further damage the Playstation 3. Contact a member of Playstation Support for information on console maintenance.
Thank you !!
SOURCE: Ps3 wont read ps3 games
It sounds to me like you might have a dirty laser inside the ps3, which could put a real strain on the reading of disks, your ps3 should have warranty left on it if not there are people who can replace this for around 30-40 quid
hope this helps.
SOURCE: ps3 wont read games
the lens eye maybe dirty clean it rubbing alcohol on a Q-tip. gently clean the eye and use the other end of the Q-tip to dry the access rubbing alcohol.
