Question about Boating
Suzuki outboard motor 65 hp --oil sensor keeps
Suzuki outboard motor 65 hp "suzuki dt65-"-oil sensor keeps going off as an alarm. How do we fix this problem?
Posted by lori_1442 on
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
Assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Posted on Jun 20, 2010
How do I remove the oil reservoir from a 1999 Mercury outboard 50 horsepower motor
good idea to remove the alarm rather than fixing the fault
after all you could run out of oil , ruin the motor completely because of the lack of oil and have a long swim home
fix the error in the alarm / sensor and be safe
Jul 02, 2017 | Mercury Cars & Trucks
The two check eng and temp lights do not come on when I first turn switch to start on. Suzuki 60 2014
check the oil pressure first with a test gauge, as far as the other light goes have you over revved the engine?
May 22, 2016 | Suzuki Motor, Power Trim, DF60-70 98-00,...
HAVE TO REPLACE A CDI UNIT NEED A BREAKDOWN DT65 SUZUKI 6501
Suzuki DT65 1978 Wiring Diagram Page: 1 - iboats Boating Forums ...
forums.iboats.com/...suzuki.../296297-suzuki-dt65-1978-wiring-diagram Jan 5, 2009 - 6 posts - ‎4 authors ... diagram for a Suzuki DT65 6501 D-10978 (assume this is 1978). ... I looked around for a shop service manual on the internet, located a ...
Jun 23, 2015 | Suzuki Motorcycles
I have a 65hp suzuki outboard motor wont start just makes clicking noise and tilt aint working now motor was running season before
try installing a fully charged battery or charge the battery for 24 hours then jump start the boat from a car
Jun 24, 2014 | Suzuki Service Manual, 2 - 65 HP Outboards...
Flashing light oil
NO THE OIL IS OK , THERE IS NO FLASHING LIGHTS
Feb 02, 2014 | Suzuki Motor, Power Trim, DF60-70 98-00,...
Hot engine alarm on my 1998 115 hp mercury outboard as soon as you turn the key on the alarm comes on and does not stop until you turn the key off ?
Alarm is also for low oil but cold be faulty relay unit for alarm.connect heat sender wire straight to alarm and just make sure you always have oil in autolube
Sep 20, 2013 | Light Outboard Motor Boat Bass Fishing...
I just bought a suzuki outboard dt65 it sat for 6 years what do i need to do for water ready
remove carbs and clean jets etc ! clean or replace fuel tank and check primer bulb and line not perished ! check compressions and sparks ! remove gearbox and replace the impellor even if it looks ok and replace the gear oil ! run in tub of water for an hour to check cooling and the thermo opening also check no fuel leaks etc !
Jul 24, 2011 | Suzuki Boating
I have a Suzuki DT65, all is fine until motor warms up then i loose mid range, it's either idle or flat out, can someone help with this problem.
have a Older DT65 and the MOTOR is clean but wont tur over and sounds like a bearing in grinding or somthin
Aug 12, 2009 | Boating
Boating Logo
1,294 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
