Question about Mag Innovision LT765b 17" Flat Panel LCD Monitor
My MAG flat screen flickers uncontrollably- can't see a thing
My MAG flat screen monitor recently begun to flicker after 5 min.s of use, til the screen goes crazy (gets all "jumpy"), and I have to shut down. I have to wait a day or so and try again to get 5 minutes out of it, so it's virtually unuseable at this point. It's less than 2 years old. I also can't get the vga cable off the back where the "DC IN" slot is, because it's impossible to turn the connector to loosen (wrench won't fit). I noticed this because I tried to hook up an alternate monitor to verify whether the problem was with the monitor or with the CPU... it's the MAG monitor!
Any idea what's going on, is my monitor already dead?
Posted by susgra on
5 Related Answers
Anonymous
  • 198 Answers
SOURCE: Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Anonymous
  • 138 Answers
SOURCE: MAG Innovision LT916S monitor problem
Hi this is the way how to examine what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Posted on Mar 15, 2008
Anonymous
SOURCE: My MAG Innovision Monitor went blank, only works if I stay connected to internet
usually this problem is caused by a faulty inverter circuit. transistors might been running too hot or a leaky capacitors also.not an easy task but try looking down for any defects on high voltage sections.
Posted on Mar 18, 2008
Mergatroid
  • 286 Answers
SOURCE: MAG Innovision 19" TFT LCD Flat Panel Monitor
the monitor has bad backlights or circuitry. Call the company, their number should be in the owners manual. Or, look on the web for their website. Or, call the store where you bought it. The monitor must be taken to a service centre for repair.
Posted on Mar 27, 2008
Anonymous
SOURCE: Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
Posted on Aug 06, 2008
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
4helpful
2answers
Purchased a 42-Screen "flickers"
Inverter Board going bad or loose plug, then the backlight board will fail within 3-4 weeks later. Good thing you saved a few hundred on the x-warranty, BB won't do a damned thing for you regardless; it's discontinued & they lie about their 'replacement vouchers'.
A 12" bi-metal blade is recommended for your reciprocating saw so that you can cut this thing into small enough pieces for your trash collection.
Acer al2423W lcd monitor has begun vert-flickering
that happens when the monitor is on the way out i think you looking at new one
Flickering screen
My screen flicker on xp but on win7 please help me?
Regards, Chas
1helpful
2answers
Flickering monitor
Flickering screen display
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
  • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
    • a TV set
    • a laser printer
    • another monitor
    • fluorescent lights
    • hidden power lines
  • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
  • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
  • The number of devices using power from the same electrical line. Are you overloading the plug?
  • Monitor placed on an unstable surface.
  • Improper video drivers, this is a software problem, see section B
  • An improperly configured or a defective video card.
2answers
Serious problem
Check WGA if it is correctlly put on and go to DISPLAY PROPERTIES - SETTINGS - ADVANCED -MONITOR
Ocassional flickering
Not sure what the problem is, but am experiencing the same symptoms every few minutes on a Mitsu Diamond Pro 91TXM, just retrieved from storage after 7 years. How's your screen holding up since April?
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Mag Innovision LT765b 17" Flat Panel LCD Monitor Logo
Top Mag Innovision Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
